To Rebuild or not to Rebuild
Old May 7, 2009 | 01:54 AM
If it ain't broke don't fix it. I never lived by this. I live by "if it ain't broke, upgrade it".
There is something going on with that motor. Do your testing and then let us know. You might not need to pull the whole motor. It could be a valve causing you issues in which case you would only need to pull the head.
Old May 7, 2009 | 05:51 PM
please tell me you've read my oil post
Old May 7, 2009 | 06:41 PM
sgp7679's Avatar
well find out whats wrong with it first. If its nothing too major, just fix the small problem and keep on rollin. If your keeping it until I have to pry it from you, you can rebuild later in life when the engine blows up.
Old May 8, 2009 | 07:10 AM
Red Devil's Avatar
Little Demon
the way I see it (and this is just my opinion) the coolest cars are the all #s matching surviors. I think you just need to figure out what is wrong with car before you start getting ahead of yourself. If its got to be fixed, its got to be fixed. If it were me, I would do only what is required to keep it moving, I wouldn't start doing massive resto and rebuild unless it really needed it, but that is just my opinion
Old May 8, 2009 | 08:01 AM
Crazy4Carz.Com's Avatar
Stop screwing with it and let a pro take a look. The car is worth it.
Old May 8, 2009 | 05:47 PM
Commando's Avatar
Originally Posted by stickshifted
+1
i forgot to add, if you havent already, you NEED to buy the book "How to Rebuild Big Block Mopar Engines" there will be a lot of information the section, "Is it time to rebuild?" and im referring to the older book that came out in the 80's.
I recommend this book to anyone with questions about their engine, it is an invaluable resource, I used it while I rebuilt my 440 and any question I had I could find it in there.
Old May 8, 2009 | 06:44 PM
scotts74birds's Avatar
Did you know that if you have one of those Laser I.R. thermometers, you can check the exhaust temps at the headers for each cylinder and help narrow things. I.E. a hot or cold running cyllinder?
Old May 8, 2009 | 11:00 PM
chlngr1970's Avatar
DUDE! Awesome tip!
j
Old May 8, 2009 | 11:29 PM
Even a blind squirrele finds a nut once in a while!
crwchf16
Jun 3, 2012 03:08 AM
koondawg_74 roadrunner
Sep 2, 2010 08:33 PM
