rims and tires help
Old Jun 3, 2010 | 11:58 AM
dusterboy89's Avatar
rims and tires help
i have a 72 duster that has stock rearenddoes anyone no the biggest slick i can run on the back like tallness and width wise thanks
Old Jun 3, 2010 | 12:03 PM
mopardrt's Avatar
just call ur local tire shop they will be able to help, just remember it has small blot rims when you purchase a set or wheels and without mini tubbing you wont be able to go to wild and crazy whithout running into problems will want to run a 15 inch rim my tires on my dart right now are 8 inchs with about 2 inchs to spair i dont see you getting more then 10 inch tires under a stock duster
Old Jun 3, 2010 | 12:24 PM
Archer's Avatar
duster -
Just a thought, unless you're already running a veyy steep gear ratio in the back, you might not want the tallest slicks you can get, you might want the shortest. Going with a smaller diameter will usually give you more rpms (like a higher number rear ratio) and give better clearance.
Street tires are a different kettle of fish.
Just a thought.
Old Jun 3, 2010 | 05:12 PM
I'm gonna run 410s in the rear and prolly get some axels
josehf34
Aug 13, 2014 05:53 AM
mytracy
Apr 19, 2011 06:15 PM
chargerking1486
Mar 14, 2011 09:57 PM
dhetticher
Mar 12, 2011 09:21 PM
67 GTX
Aug 13, 2009 04:43 PM
