small block head gasket leaking?
Old Jun 21, 2009 | 11:46 AM
DUST360's Avatar
Junior Member
408 stroker 360, high compression around 12:5. I noticed some antifreeze under the car and put it on the lift and saw wet spots on both sides of the heads where they meet the block in. I over heated the car pretty bad last year and have eddy jeahs on it. Did I smoke the head gaskets or wrapped the heads or is this common on a high compression engine or should I tear it apart? I can email pix
Old Jun 21, 2009 | 12:39 PM
no motor should even leak any fluid. I would start by taking off the heads and looking at the gaskets. Also have the heads checked for flatness as alum warps pretty easy from what I have read.
I'm not sure how well copper head gaskets will work with alum heads but you may have to go that way.
Old Jun 21, 2009 | 01:53 PM
Polaradude's Avatar
Is there any coolant on the dipstick ? and x2 on the pressure test.
Old Jun 21, 2009 | 07:35 PM
like polara said, is there any anti-freeze in the oil?
Old Jun 22, 2009 | 01:38 AM
or oil in the anti-freeze?
Old Jun 22, 2009 | 08:16 PM
DUST360's Avatar
Junior Member
tore evry thing apart. little antifreeze in oil, but was clearly leaking on both sides where heads attach to block.????
Old Jun 22, 2009 | 09:32 PM
probably just bad head gaskets
moparfreak66
Sep 13, 2011 01:59 PM
tagster
Sep 9, 2010 01:04 PM
jascharger
Jul 14, 2010 07:04 PM
sgp7679
Jan 7, 2010 12:58 AM
MarkyMark12345
Apr 16, 2009 06:46 PM
