SRT-8 setup
Old May 18, 2011 | 11:09 AM
bugy's Avatar
Question SRT-8 setup
I got a charger 1970, i was wondering about a SRT-8 engine going into this car, but i don't know if i'd have ignition and computing issues, what do you say?
Old May 18, 2011 | 11:59 AM
Whatever you pull the motor out of, pull the wiring and computers with it as it will make the swap much easier.
Old May 18, 2011 | 04:10 PM
bugy's Avatar
don't you know if there's a aftermarket brand where i can get, all the stuff im gonna need for this setup like ecu, harness ecu, brakes, suspention, etc.
all advices are well received, thanks
Old May 18, 2011 | 06:40 PM
Crazy4Carz.Com's Avatar
the entire build is right here:
http://www.crazy4carz.net/carzboard/...t&referrerid=1
Old May 18, 2011 | 08:11 PM
That is right. Steve did this in his Dart. Everything that you would need I'm sure that he will be able to help you with or point you in the right direction.
Old May 19, 2011 | 11:08 AM
bugy's Avatar
Question
i dont know if you are steve, but if you are, that was an amazing job, im glad i could appreaciate such a motivating project, well sir of course it helped me out a lot (suspension, brakes, rear and front end),but i still need ecu to make this SRT8 engine work i'll use it with fuel injected so this is gonna be swapped into another car (charger 70), so i suppost original ecu from srt8 won't work with this setup because of alarm, brakes, and all issues it works with, i've seached for it, but can't find it yet, any aftermaket?
Old May 19, 2011 | 11:33 AM
MrOldart2U's Avatar
No he isn't Steve, Crazy4Cars is, the one that did the build. And not knowing how alarm/brakes, and other misc circuits/systems the ecu has, i have heard that those circuits are not needed to make one go. But to answer your question, yes aftermarket ecu's are out there and available. This is one that comes to mind...FAST
Old May 20, 2011 | 05:40 PM
scotts74birds's Avatar
Getting to be a pretty common swap. The Cheby guys have been doing this for years. Finally getting more info out there for the Mopar crowd.
Old May 21, 2011 | 11:15 AM
bugy's Avatar
guys, i already got the ecu i was looking for it is from MSD i just need the harness for factory fuel injection MSD do not sell it, any idea? FAST doesn't, they told me to look for it in Chrysler or get it in a salvage yard, any idea? this timing controller is PN 6013
unruler
Mar 26, 2009 05:30 AM
gilligan
Mar 18, 2009 04:52 AM
Crazy4Carz.Com
Feb 3, 2009 10:43 PM
GTXpress
Nov 25, 2008 10:30 PM
Whiskey
Sep 11, 2008 06:25 AM
