stalling problem
Old Jun 15, 2012 | 07:14 PM
michuy's Avatar
stalling problem
got an ol 73' d100 with a 318/727, that stalls when put in gear. motor idles and takes throttle just fine in Park or N. haven't a clue what is causing this.
Old Jun 15, 2012 | 07:19 PM
Vacuum leak or torque convertor. Check all your vacuum sources for leaks.
Old Jun 16, 2012 | 07:19 AM
70Coronet's Avatar
I agree with bremereric, sounds like vacuum leak, a easy trick to help find it is to start it up and use a can of carb or brake clean and start spraying around intake pay attention to the idle-if the idle starts to go up or it dies figure out where you were spraying the cleaner when it died, if its something like a intake leak this will help point it out-hope this helps-also when you put it in gear try to do it without holding it back with the brakes or depending where you live maybe let it roll a little in nuetral then pop it in gear, if its the converter it probably wont die if you are moving when you put it in gear.
ROCKY
Resources
Jul 28, 2012 05:45 PM
D5PARKER
Jul 1, 2012 01:13 PM
twalace
Jun 26, 2012 12:02 PM
Salty
Dec 17, 2010 12:33 PM
mkendrick111
Mar 13, 2009 10:21 AM
