Starter Relay
Old Yesterday | 08:31 PM
cudaman496's Avatar
Starter Relay
On my 72 Cuda, I turn the key to start, and nothing happens. Starter Relay has 12V to it from the battery. Was thinking might be the Neutral Safety Switch,
but can't get a new one on there due to clearances. Can I just ground the wire coming off the starter relay, which goes to the NSS,
so the engine will start. Can I leave that wire connected to ground? The connection on the starter relay that gets the 12v ignition start signal
is also getting 12 volts. thanks Or maybe I just need a new starter relay?
Old Today | 05:58 AM
Do you have power to the NSS ??
If Yes...
Do you have ground to the NSS ??
If Yes, the switch is bad... Just install a jumper wire until you ban source a new switch.... Bewear !!!! The car will start in any gear that is selected....
Old Today | 09:18 AM
cudaman496's Avatar
thanks, would the jumper wire be from the terminal on the Start Relay to ground?
rcknrolfender79
Apr 9, 2015 08:32 AM
duster3
Oct 2, 2013 02:46 PM
BHamalian
Aug 14, 2013 04:55 PM
Steffany
Aug 20, 2012 09:44 PM
70newport
Aug 19, 2012 10:39 AM
