Stock dodge dart axle
Old Jan 7, 2010 | 10:59 AM
xjonathanx's Avatar
Hey Im trying to do some reasearch right now on my axle, but i cant find the info im looking for, so im asking anyone who would know. I need to know what back axle comes on a 1970 Dodge Dart Custom 4 door. I need the info so i can figure out gears and what not. THANK YOU
Old Jan 7, 2010 | 03:54 PM
toad490's Avatar
7-1/4.....9-bolt rear cover.
8-1/4.....10-bolts, evenly spaced, cover is almost perfectly round.
8-3/4.....No rear cover, round.
9-1/4.....12-bolt rear cover.
9-3/4.....10-bolts, cover has about 6 uneven straight edges.
Old Jan 8, 2010 | 01:49 AM
Crazy4Carz.Com's Avatar
there is a tag about the size of your thumb under one of the screws that will tell you.
Old Jan 8, 2010 | 04:38 AM
You can also pull the cover and look at the ring gear as it should say the ratio or give you two numbers that when divided give you the ratio (ring gear tooth count and pinion gear tooth count), or you could count them yourself and divide the ring gear by the pinion gear.
Also depending on the axle there will be a tag like C4C mentioned and/or a tag that is being hels on by two bolt on either side of the diff cover.
Old Jan 11, 2010 | 07:14 AM
xjonathanx's Avatar
sweet thanks alot
Old Jan 24, 2010 | 03:01 AM
deadkelly's Avatar
you can jack the rear of the car up & while it's in netural turn the tail shaft around one full turn & count how many times the wheel turns . ??? is that right ???
Old Jan 24, 2010 | 07:25 AM
MrOldart2U's Avatar
DK ya have it backwards... turn tire (or tyre....lol) and count driveshaft revs.... its going to be the one turning faster than the tires, and one turn of drive shaft wouldnt tell yo cause the tires wouldn't make a full revolution.. and i think they suggest to do 2 tire revs, then divide X2... dunno why ..... but i know ive read that somewhere. I just go 1X it gets to with-in .01 or so... depends on mfgr (ie 4:10 vs 4:11)
Old Jan 24, 2010 | 07:45 AM
deadkelly's Avatar
cool thanks . i was in the ball park some whereish .
KCaro81
Dec 17, 2014 09:21 AM
Canyon
Oct 1, 2014 06:49 AM
ghubb4x4
Sep 17, 2013 09:29 AM
MReeves
Stock Eliminator
Dec 12, 2011 10:26 AM
$eth
Oct 7, 2009 05:47 PM
