tf 904 trans help
Old Oct 8, 2009 | 08:45 PM
78cordoba's Avatar
Member
tf 904 trans help
hey guys, i just installed my "newer" 904 trans in my 78 Cordoba and took it for a ride with the shifter in [D] it shifts great from 1st to second then when it shifts to 3rd it feels like its in neutral and if i try to give it gas it just revs and pulls a little. i was thinking maybe the band needs to be adjusted? or do you guys think its something else?
thanks a lot
mike
Old Oct 8, 2009 | 11:47 PM
Please explain "newer". Is this a trans that you (or someone else) pulled from another vehicle? Did you drain the pan, install a new filter and or flush the whole tranny before running it?
Old Oct 9, 2009 | 03:22 AM
Here is a 904 Repair manual.... Hope this helps..... Mack
http://www.imperialclub.com/Repair/L.../145/index.htm
Old Oct 9, 2009 | 09:38 AM
78cordoba's Avatar
Member
the trans was pulled from another vehicle and yes i drained the pan and changed the filter before
ps thanks MReeves for that manual
Old Oct 9, 2009 | 10:21 AM
Crazy4Carz.Com's Avatar
It is likely not going all the way into "D" and slipping. adjust the linkage before you even move it.
Old Oct 9, 2009 | 12:02 PM
78cordoba's Avatar
Member
is there an easy way to adjust it?
Old Oct 10, 2009 | 06:28 AM
rr69half6bbl's Avatar
doba, whether its col. or floor shift, after you raise and support the car, underneath, unhook the linkage from the trans arm. place the trans arm in D, then make sure that the shifter is in d. then the linkage bar has a bolt on the top of it, you loosen this bolt, then the lkg. piece moces back and forth on the arm. you move it till it will fall right into the shift arm on the trans. the secure itand tighten the bolt back, try to shift it in the car then. if it still persists, id say you have internal probs. and not shift wise. Did you reinstall the kickdown lever from the carb,to the trans?
gsxrred1000
Jul 8, 2013 10:39 PM
73 dart swinger
Sep 18, 2011 09:21 PM
89PowerRam
Jun 24, 2010 03:33 AM
crashcaptn
Jan 14, 2007 04:46 PM
