Is there a different driveshaft for big block cars?
Old Oct 15, 2010 | 07:24 PM
Mango's Avatar
I am swapping a 440 into my 318 E-body. I have a 8 3/4" rear. I bought a big block yoke (7290) for my 489 third member. The auto part stores offer two different U-joints (big or small yoke). How are these U-joints different? Is there a BB driveshaft that I should be looking for or can I reuse my driveshaft?
Thanks!!
Old Oct 15, 2010 | 09:15 PM
1966sportfury's Avatar
A.K.A Bob Dodge
if i rember right it varys by car? some use bigger u joints, but you can keep your stock driveshaft and use a combination u joint 2 ends small two ends bigger
Old Oct 16, 2010 | 06:41 AM
Archer's Avatar
Mango -
Definite maybe. The BB will have a different tranny (bell housing) and the overall length might be different. When I switched from a 318 to a 440 in my Charger, I needed a LONGER drive shaft to fully engage the tranny spline. Yes, the rear U-joints may be different too, but that's not usually a problem as when doing the conversion, unless you get very lucky, it's a good idea to have a custom drive shaft made, or your old one "re-built" to the new specs. That's what I did.
Old Oct 16, 2010 | 02:42 PM
blue 68 gts's Avatar
Originally Posted by Archer
Mango -
I'm pretty sure a small block tail shaft and big block tail shaft are different lengths.
you'll just need a completely new trans, and drive line. I'd suggest having a brand new one built with brand new u-joints. The 1050 ones is what I run.
Then you really don't need to worry about breaking anything behind the transmission.
Old Oct 20, 2010 | 04:47 PM
scotts74birds's Avatar
Heres a FAQ site from Dennysdriveshafts. http://www.dennysdriveshaft.com/freq...questions.html This should help you with some questions. It explains u-joint sizes too.
Old Oct 20, 2010 | 07:13 PM
Silverick's Avatar
You're right about the larger yoke/u-joints.
The change from small to large coincides with the engine size and the change came at the 383.
The 383 with a 2 barrel came with the small u-joints and the 383 with the 4 barrel came with the large u-joints and yokes. The step up to the large stayed through the 440 range.
2thpic
Apr 6, 2012 12:20 AM
pipdog69
Mar 13, 2012 11:01 PM
69SatSport
Dec 3, 2011 11:42 AM
mystarcollectorcar.com
Dec 21, 2010 11:31 PM
mahd
Apr 2, 2009 09:05 AM
