torque specs on intake manifold
Old Dec 18, 2009 | 01:31 PM
beep1969's Avatar
Junior Member
if anyone knows the torque specs for the intake on a 383 it would be appreciated
Old Dec 18, 2009 | 04:36 PM
scotts74birds's Avatar
Factory, or aftermarket aluminum?
Old Dec 18, 2009 | 06:56 PM
Crazy4Carz.Com's Avatar
Working from the inside out in a "spiral" pattern, I like three pulls, first to ~30, second to ~60, and the last pull to 90ftlbs. This is the spec I use with ARP studs (Oiled) Factory bolts should be similar. Wait for someone else to chime in, this is just the way I do it, that doesn't make it "by the book".
Old Dec 18, 2009 | 08:08 PM
WHAT! Sorry, thats head specs, not intake.
Old Dec 19, 2009 | 06:08 AM
beep1969's Avatar
Junior Member
it's the factory iron intake manifold.
Old Dec 19, 2009 | 06:37 AM
What a dumb ***! I guess I can't even read! Sorry .
Old Dec 19, 2009 | 06:41 AM
3forty's Avatar
Junior Member
The '69 factory manual says a final torque of 40 ft lbs.
Old Dec 19, 2009 | 07:14 AM
beep1969's Avatar
Junior Member
torque specs
40 lbs in a general star pattern i'm assuming?
Old Dec 19, 2009 | 03:16 PM
3forty's Avatar
Junior Member
Finesse the bolts down,yes star pattern slowly adding torque until you reach 40 ft lbs.
JETBLU
May 1, 2015 04:05 PM
jdewoskin
Aug 7, 2010 02:14 PM
M1 Manifold
May 21, 2009 02:23 PM
Mar 18, 2009 06:33 PM
got2mopars
Sep 22, 2007 05:44 PM
