Transmission identification help
Old May 23, 2022 | 04:30 PM
Dakota96's Avatar
Can somebody point me in the right direction of how to decipher the code on side of my transmission I believe it’s a 727 but would like help with e the stamp code 4058326M6227 85 that’s all the numbers I could get off the side of it thank you in advance
Old May 23, 2022 | 06:36 PM
This might help, the pan identifies close enough for me.
Old May 24, 2022 | 09:46 AM
yeah, pan shape tells the tale. what's it in? that's a good hint, too. if it's a passenger car from the '80s with a small block, likely not a 727. but if it's a big truck, 4x4 or the like with a nice payload rating, then it could be.
Old May 24, 2022 | 10:45 AM
Dakota96's Avatar
It was bolted to a 440 and came out of a 75 dodge camper didn't see camper picked up from guy I work with
Old May 24, 2022 | 10:48 AM
I'd say chances are good it's a 727 then, though it could technically be called a 36RH or 37RH by then, but same idea.
Old May 24, 2022 | 10:49 AM
Oh, it came out of a '75 lol... it's early. Yeah, 99% it's a 727 bud...
Old May 24, 2022 | 11:03 AM
Dakota96's Avatar
Thank you
Old May 24, 2022 | 01:42 PM
There were various 727 transmissions, short tail shaft, park brake drum on the tail shaft and it might have had a flange mount instead of a slipyoak and then the slipyoak but all of these are easy to identify and required a full teardown and rebuild too change the tailshaft.
I forget about the 4x4 727.
Old May 24, 2022 | 02:03 PM
Dakota96's Avatar
Iowan could I take pictures of trans and Sen to you thru dm?
Old May 24, 2022 | 02:48 PM
Post them here.
300awd
Sep 2, 2021 01:35 PM
Les Liley
Mar 29, 2013 12:25 PM
jaygr
Oct 24, 2012 02:39 AM
CantRamItDodgeIt91
Jun 12, 2010 10:43 PM
azcuda
Cuda Specific Discussion
Jul 13, 2009 08:55 PM
