Trying Decode Motor Plate Numbers E 440
Old 02-10-2012, 04:21 PM
Potterymaker1's Avatar
Trying to figure out what type of car my 440 came out of. Currently in a 1969 Dodge Charger RT. I strongly believe motor is original but not certain. Marked on Block Vin Pad E 440 12 16HP2
Also trying to figure out if I need a weighted stall convertor or a non weighted convertor for that motor.
I would appreciate all help. Thanks Ben
Old 02-11-2012, 09:04 AM
pops1967GTX's Avatar
Check All weights are located and tack welded on the torque converter ...
the Use a flex plate with the balance built into it. Then you can use any converter
http://www.moparengineswest.com/Stampings.htm
Old 02-13-2012, 07:20 AM
BuckNeccid's Avatar
Look on the bottom right side center of the block, close to the rail where the oil pan meets the block. In '69, if it's a numbers matching engine, you will see at least a portion of the serial number on a flat machined pad. If the serial number matches, then you have the original engine in the car.
The E440 IS correct for a 69 model car, so you just might be right
E-Muscle LLC
10-01-2014 07:52 PM
Dizzle
04-19-2010 01:25 PM
bighammer
04-11-2009 07:24 PM
ddot921
09-30-2008 07:45 PM
71RR08
08-22-2008 12:10 AM
Quick Reply: Trying Decode Motor Plate Numbers E 440
