Undercoating
Old Jun 20, 2009 | 06:48 AM
Crazy4Carz.Com's Avatar
I've stripped mine in the past as well. But rather than do it myself I was fortunate enough to have a media blaster local and had mine done for about $150 bucks. Check your yellow pages and see if you have someone that does this in your area. Another good source is some of the restoration shops, they may be able to give you a referral. Good luck.
Old Jun 20, 2009 | 07:37 AM
a sand blaster works well. only thing is that it blows sand all over the place as well. have you tried a wire wheel that has the twisted wire, not the straight?
Old Jun 20, 2009 | 09:11 AM
I would scratch it up but I would think that you would be doing something with it anyways.
Old Jun 20, 2009 | 10:43 AM
theomahamoparguy's Avatar
media blasting is like sand blasting only it uses plastic media instead of sand. Easier on the metal cause it doesnt heat it up as much.
...but...
Have you tried using a hand held heat gun. {think heavy duty hair drier}Sometimes they will loosen up the undercoat enough that u can scrape it off with something that wont harm the paint.
camfreak1
Jan 1, 2014 02:47 PM
70newport
May 22, 2013 07:32 PM
Marc Greenleaf Jr
Aug 15, 2011 03:57 PM
smackhonda
Sep 4, 2009 07:11 PM
