Upgrading the compression ratio on a 440
Old Sep 7, 2012 | 11:25 AM
mopwit's Avatar
Hi all
I hope to soon have a car (circa 73 - 75) with a 440 engine. I know this engine will have a compression ratio of 8.2:1.
1) What should be done to raise the compression ratio to around 10.5:1? I would not want to skim the heads or the deck.
2) What info do I need to have about the engine before I can set about buying parts?
TIA
mopwit
Old Sep 7, 2012 | 12:11 PM
As explained previously The only other way is to re bore the engine and replace the pistons
Old Sep 7, 2012 | 04:25 PM
There are only 3 ways to raise compression
mill the heads
mill the deck
change the pistons
or various combinations of the above
Old Sep 7, 2012 | 06:28 PM
Archer's Avatar
mopwit -
What the guys said, but think twice before you do any of that.
The easiest route would be new pistons, but make sure you have valve clearance. Milling the block and or heads will leave you with manifold alignment and push rod length issues which will need to be addressed. (Not impossible, but annoying.)
When gas octane went down in the 80's, there where a number of articles in mags like Hot Rod, Car Craft, etc about making low (8:1) compression engines perform.
If you're not building a race car, stay with the lower compression ratio might save you a few bucks on gas.
Old Sep 8, 2012 | 09:06 AM
Run the same pistons as me. Kieth Black 237 pistons have 5cc valve notches and mill the deck .010 and the heads .010 and you will be right in the ballpark. With 80cc combustion chambers on the heads you will be at 10.6 to 1.
josehf34
13
Jan 13, 2014 09:35 AM
RustBeltRodder
Aug 19, 2011 07:50 AM
panda!
Jun 17, 2009 01:53 AM
8287rams
Apr 21, 2009 07:46 PM
135sohc
Dec 15, 2007 08:33 PM
