What the best mopar original motor?
Old Mar 14, 2008 | 07:08 PM
I would tend to stay away from early hemi's because they aren't that plentiful, and performance parts can be expensive.
If you are going for the "factory" look, just about ANY big block Mopar will look at home in there, from a 383/400/413/426/440, all fit the same, pretty much. 413's and 426's are a little hard to find. Probably the most plentiful are 383/400's and don't cut them short. Even 400's have turned out to be good engines.
Also, once you get it together, if you run into something better, it just isn't that hard to swap something else in there, once it's set up for a B block.
Mbling52
Jan 27, 2016 09:55 PM
tahoeskier
Jun 18, 2011 06:59 PM
mystarcollectorcar.com
Dec 22, 2009 06:54 PM
Cudafever
Mar 18, 2009 10:43 PM
mahd
Oct 23, 2008 08:09 PM
