what is a golden lion engine?
I bought this either 383 or 413 engine out of a bone yard, it was in a motor home but the exterior was missing so I could not find a production date.
Can someone tell me where to look for numbers on the block, are they located behind the a/c bracket stamped into that flat spot on the block?
I have a 76 440 block and the cu in is cast into the block did they also do this to all their engines.
The engine has a torque converter and flywheel (one piece) which is bolted to the crankshaft and the ignition system is points not electronic.
Thanks for any help.
If memory serves there were two Golden Lions, one was a 383 and the other a 413. There will be numbers on your block like Commando said. Get the numbers and we will decode it for ya. May I ask why you think it's a lion ?
Does it have the GL breather ?
