what is a golden lion engine?
Old Apr 3, 2010 | 01:54 PM
mopsled's Avatar
Junior Member
I bought this either 383 or 413 engine out of a bone yard, it was in a motor home but the exterior was missing so I could not find a production date.
Can someone tell me where to look for numbers on the block, are they located behind the a/c bracket stamped into that flat spot on the block?
I have a 76 440 block and the cu in is cast into the block did they also do this to all their engines.
The engine has a torque converter and flywheel (one piece) which is bolted to the crankshaft and the ignition system is points not electronic.
Thanks for any help.
Old Apr 3, 2010 | 04:01 PM
Commando's Avatar
If there is a flat spot on the block behind the water pump housing thats a 440. Look there or on the side of the engine above the oil pan.
Old Apr 3, 2010 | 04:11 PM
Polaradude's Avatar
If memory serves there were two Golden Lions, one was a 383 and the other a 413. There will be numbers on your block like Commando said. Get the numbers and we will decode it for ya. May I ask why you think it's a lion ?
Does it have the GL breather ?
Old Apr 3, 2010 | 04:29 PM
1966sportfury's Avatar
A.K.A Bob Dodge
yeah. the golden lion did come with a rb 383 and an rb 413.. all rb engines have that flat spot commando is talking about.
aaron501420
Jul 31, 2022 04:54 PM
clarkboy33
Mar 11, 2013 12:54 PM
prachts350
Oct 2, 2010 04:28 PM
ProEmaster
Jun 6, 2007 11:31 AM
