What Junk yard carbs would work on my truck?
Old Jul 11, 2010 | 05:52 PM
Tiretrack's Avatar
Junior Member
The qjet in my pickup is getting pretty worn out. I've read about rebuilding them, but i dont want to pay for it, or deal with it. ( a difference of .0001 in the idle tube size will mess the whole thing up)
Carter carbs were really common on older mopars right? So any AFB/AVS
should work? What about the thermoquad, did they come in non-emisihions form.
I've looked at the eddy carbs, any i dont want to swing $200 for a reman from summit, plus the adapters and such.
Anyone have a list of carbs that would work a-Ok on my 360? I dont mind buying a square to spread bore adapter. Will a square bore carb mess up my gas milage? I'm on an all time high streak of 14.
Old Jul 11, 2010 | 06:40 PM
Barfly's Avatar
To the best of my knowledge the Edelbrock Performer Series carbs are the Carter carbs, as Edelbrock bought Carter out.
I have a Carter 9606 and the Edelbrock 1405 is same same.
Doesn't answer much of your question, just some info.
Joe.
Old Jul 11, 2010 | 09:33 PM
1966sportfury's Avatar
A.K.A Bob Dodge
Joe.
well edlebrock didnt buy out carter, carter was bought out way before edelbrock though about the carbs, many times, weber owns the afb/avs design and produces the carb for edlebrock. the thermal quad has the emissions hook ups but they work fine on older engines, the thermal quad will get better mpg due to the small primary's. the afb/avs carb will work just fine, 525/600 cfm afb. 525/750 avs, 600/800 thermalquad
Old Jul 12, 2010 | 03:48 AM
Barfly's Avatar
Thanks buddy, I stand corrected.
Old Jul 12, 2010 | 05:16 AM
Tiretrack's Avatar
Junior Member
I'll see what i can come up with tommrow, too windy today.
Old Jul 12, 2010 | 02:52 PM
Crazy4Carz.Com's Avatar
Edelbrock, webber and carter all the same.
SixtySevenDodge
Apr 10, 2009 01:26 PM
ef8340
Dec 17, 2008 12:07 AM
allenohara
Jul 9, 2008 06:47 PM
