What plug wires ?
Old Apr 13, 2013 | 09:43 PM
PURPLE HORONET's Avatar
What plug wires ?
Ordering the rest of my parts for my car.. What plug wires do you guys like best..
B-body 440 with hooker 1 7/8 headers.. What ends work best, thinking 8mm
Was thinking this set,,
http://www.summitracing.com/parts/mo...onet/year/1967
Unless theirs a better choice
Old Apr 14, 2013 | 02:36 AM
I personally like MSD but there are a bunch of good wires out there.
Are you adding a high output coil, have a ignition module and/or performance distributor? If so, I'd go with 8-9mm wires like you have. If you have neither, I'd just go with a stock set of wires.
Old Apr 14, 2013 | 06:09 AM
Archer's Avatar
Pueple -
The MSDs have a good following, but I'm an old Accel guy. The fact of the matter is, a long as you get the right type of wires, there really isn't enough of a difference to write home about.
If you're using headers, do NOT get pre-cut wires, since your routing will not be anything like stock. It's a good chance to get creative. (Since you can't hide them, show 'em off.)
Most applications work best with 90* plug boots. You may also need wire "sleeves", the insulated tubes that go around the wires at the plug end. They really are a wire saver.
Depending on your header configuration, going to "shortie" or "peanut" spark plugs can also add clearance. I use the Accel short plugs, those plus the wire covers made a big difference.
Old Apr 14, 2013 | 08:08 AM
PK1's Avatar
PK1
I prefer MSD Super Conductor.
When testing wires once to determine if one had bad cord I was extremely surprised to see how little resistance these had compared to other "High Performance" wires.
I had Ford MS 8mm, Chevy 8mm, Summit, Mopar, and some Taylors ( low price point ones) at the time. There was no comparison. I did not test Accel and have used them on bikes with good results.
In the spirit of full disclosure the MSD were twice as much as the lower price 8mm items but the difference at the meter was large.
Old Apr 14, 2013 | 08:11 AM
jacilynn_s's Avatar
The best longest lasting wires are bare none the factory sets, which are available date coded from chrysler still. However since your running headers you WILL fry a few so get a cheap set like they linked above.
Old Apr 14, 2013 | 10:26 AM
I am running a mallory dual point, mechanical advance. For the reason I already have one, plus I have one in a mild 390 ford since 1990 and never once stuck a set of points in it..
If I had to buy a new set up it would be MSD with a 6al box
Old Apr 14, 2013 | 06:17 PM
Originally Posted by moparted
more nonsense, those wires only belong on a restored trailer queen
Yah if I want stock I get the baldwin from Napa
Old Apr 14, 2013 | 07:41 PM
jacilynn_s's Avatar
Giggle you guys. I'll continue to giggle my butt off as you pop and fart with failed non mopar wires continuously while I run trouble free with my stock mopar wires for 15+ years.
Good luck.
Macjeep
Jun 19, 2012 12:01 PM
May 17, 2010 08:32 PM
Morrigan_Aria
Aug 6, 2009 07:04 PM
Jun 10, 2009 01:53 AM
rabys
Mar 22, 2008 11:37 AM
