Built N/T D44 axles - Manchester, NH
Old Jan 7, 2011 | 05:37 PM
First axle - 1986 Grand Wagoneer N/T front D44 - ALL SOLD
Driver side drop
New 5.38 gears
Full Detroit locker
New Yukon 4340 chromo inner (30 spline)/outer (19 spline)axle shafts
New D44 CTM u-joints
New HD Spicer ball joints properly setup
Flat top knuckles with New Ballistic Fab high steer arms and hardware
New Ballistic Fab upper/lower ball joint gussets
New RuffStuff Specialties 3/8" thick diff cover
New 8 lug rotors, bearings and seals on 8 lug hubs
Wheel mount to wheel mount meassurement is 62 7/8" (~2" wider than a stock N/T axle)
Second axle - 1986 Grand Wagoneer N/T rear D44 - $300
New 5.38 gears - SOLD
New Strange full spool - SOLD
New Blue Torch Fab truss (1/2" thick) with tie in 5/16" thick diff cover
Ford dana 60 spindles and 8 lug hubs
New rotors, calipers, brake lines, mounting brackets and harware - SOLD
I have a pair of D70 shafts that can be cut and re-splined for this axle or Durasolid on ebay has them for $140 each for 4340 D60 shafts. - SOLD
Wheel mount to wheel mount measurement - 61 1/2"
If you don't like the gearing, we can talk about changing it. These axles are perfect for a a YJ, TJ, Cherokee, Comanche or buggy. I also have (all pieces are new and un-used) spring perches, u-bolts, spring plates, shock mounts, bump stops, stainless steel brake lines nylon coated, calipers for cores, etc. that will go with the axles IF ONLY bought as a pair. I will not sell these extras seperate. Do not ask if I will part out the axles. Buyer pays shipping. Buyer pays Paypal fee if paid that way.
Old Jan 21, 2011 | 05:08 AM
BTT with new prices.
Nobody wants to turn their Mopar in a 4x4 rig? Really? Haha
Old Mar 2, 2011 | 02:47 AM
Got enought people interested in parts and have the Detroit locker, full spool, both gear sets, knuckles and high steer arms sold so these sets are coming off the market.
Old Mar 25, 2011 | 03:09 AM
Front is gone and so is most of the rear.
1986 Grand Wagoneer N/T rear D44 with Ford D60 outers and SRW hubs (spindles can be bored to fit 35 spline shafts). New Blue Torch Fab truss (1/2" thick) with tie in 5/16" thick diff cover. Wheel mount to wheel mount measurement - 61 1/2". Asking $300 picked up.
Mar 7, 2011 05:00 PM
Mar 5, 2011 06:45 AM
Feb 6, 2011 04:44 AM
Feb 2, 2011 06:58 AM
