1970 b-5 blue dart - 225 4spd
Old Feb 24, 2009 | 07:25 AM
  #31
What size exhaust did the shop run for you? What muffler(s) were installed?
Old Feb 24, 2009 | 11:55 AM
  #32
johnthegoalie's Avatar
thinkin with me dipstick
i had the exhaust built at a race shop that does a power tune, fabricates the exhaust to the motor and dynos everything. i have the dual headers which are combined into a single 3" system with a flowmaster style muffler. it is loud and mean, at idle with the cam lope and most driving situations it is hard to tell it is a six.
Old Feb 24, 2009 | 02:38 PM
  #33
Did you ever have any head work done to it?
I'm thinking about doing 2.5" exhaust with a Flowmaster Delta 50 Series.
Old Feb 24, 2009 | 03:58 PM
  #34
yeah, the head has been milled, and ported with larger valves.
that set-up should work fine for you, before all the engine work on mine, i ran true 2" duals...
Old Feb 24, 2009 | 04:35 PM
  #35
I've got 102 to 85 PSI for compression in the motor. I'm going to see how it runs this year and next winter I may pull the head and have it rebuilt. I didn't know if you had yours ported and polished.
What size valves did you have installed? What cam did you install?
I was looking at this one -http://store.summitracing.com/partde...4&autoview=sku
Old Feb 24, 2009 | 05:00 PM
  #36
i dont have the sizes right now, when i had the car done the mopar performance /6 valves were uber expensive, the machine shop guy, one of the best mopar guys around, machined and adapted the head to accept sb chevy valves.
the cam is a mopar performance purple shaft - if i remember correctly it was the third one up from the most mild. my camshaft advice is always find one that you think is a little too much and get the next one
i have to find all my paperwork and specs, it was at my parents house and dont think it made it with me when i moved out
Old Feb 24, 2009 | 05:19 PM
  #37
when ya gonna start it again?
Old Feb 24, 2009 | 05:41 PM
  #38
hopefully in the fall. figuring everything i want to do and get the appropriate funds - if i start it i want to go non-stop - also dont like wrenching in the 120+ summers. engine is coming out, getting cleaned, painted and noisy gear drive timing set is going in. i want to revisit all the little things i neglected when it was a daily driver and i needed it everyday.
Old Feb 25, 2009 | 04:44 PM
  #39
are you gonna replace the distributor gear for safety?
Old Apr 15, 2009 | 06:38 PM
  #40
deadkelly's Avatar
Originally Posted by 66sportfury
170 whp isnt bad!! 200 wtq is awesome for a inline 6
that's awesome for a slant six ..
Old Apr 15, 2009 | 06:56 PM
  #41
deadkelly's Avatar
love ya dart john
how did you go with ya gear drive or ya gilmer belt drive ?
Old Apr 15, 2009 | 07:02 PM
  #42
chlngr1970's Avatar
How did you get the seats mounted? I have a pair of Neon seats that I am going to put in my 68 Dart when I get the floor pan replaced. I also have a pair of Cirrus seats for my Duster. I test fitted the Cirrus seats a couple weekends ago, and found the front mount points are wrong for the floor pan, and the passenger seat is a different width from the drivers seat. If you can post pix of the seats mounting points, I would greatly appreciate it.
j
Old Apr 16, 2009 | 12:40 PM
  #44
haven't made much progress on the car as far as the belt drive. found a guy in california that will custom make a kit with a v-belt groove so i can keep the ac.
cheated and half-assed it a little on the seats. on the front mounts i heated the tabs until they were cherry red and bent it 90 degrees. to level it, i shimmed the four corners and used grade 8 bolts.
Old Aug 26, 2009 | 08:26 AM
  #46
can i see a pic of the engine?
Old Aug 28, 2009 | 02:43 AM
  #47
still hot to do any serious work - i'll be washing it this weekend, i'll remember some engine pics...
Old Aug 28, 2009 | 01:49 PM
  #48
great
thanks
Old Sep 5, 2009 | 12:02 AM
  #49
after some going back and forth, finally decided on a color for the dart.
amc big bad blue
Old Sep 6, 2009 | 05:45 PM
  #50
are you going to add a strip on the car?
Old Sep 6, 2009 | 11:52 PM
  #51
no top stripe, thinking a bumblebee stripe around the back
Old Sep 7, 2009 | 12:07 PM
  #52
yaaaaaaaaaa
Old Sep 8, 2009 | 12:39 PM
  #53
still in the 100's here - waiting until it gets below 80 to start any work. every major job i've done to the car has been done in the summer heat, time to break the cycle...
Old Sep 8, 2009 | 02:01 PM
  #54
don't forget an engine pic
Old Sep 8, 2009 | 06:24 PM
  #55
here is the engine - pretty embarrassed of this pic, it's really dirty
Old Sep 9, 2009 | 03:46 PM
  #56
looks great though
Old Sep 9, 2009 | 06:56 PM
  #57
Red Devil's Avatar
Little Demon
nice. I almost bought a demon with a slant 6 but my chevy loving father said no
good luck with your car, that color will look sweet on it
maddawg57
Apr 7, 2015 06:06 AM
Brenda Harnisch
Feb 19, 2015 05:00 PM
deityxanthus
Dec 8, 2013 01:58 PM
Kona3503
Nov 25, 2013 06:45 PM
Leem
Sep 13, 2010 07:43 PM
