Tire size
Tire size
Hello Moparistas,
I have a question for you, what size would you use for a rear tire on a 1964 Dodge Polara? The rims are 15x7, I have Hi-Jacker shock absorbers (the car is raised a little at the back because of this) now I have 275/60 r15 rear tires, unfortunately when someone is sitting in the back seats and I drive over a pothole, the tire cuts slightly on the wheel well, mainly towards outer part of the fender. Wouldn't it be better to use 255/60 r15 tire dimensions?
Thanks in advance for your answer!
George
George
This should help....
https://www.americastire.com/learn/o...storeCode=1047
Looks like the 114,3mm is the 4-1/2" back spacing... If this is correct, then you will need the next size narrower tire to keep from rubbing.
