Wheels for 73 Duster
Old Dec 11, 2010 | 07:00 PM
Leem's Avatar
Hi all,
Question. Original size rims on my Duster are 14 inch. But I have removed the six and replaced it with a 383. Would going to a 15 inch rim be wise, or make any difference, or should I just stick with a the 14 inch rim?
Thanks,
Marty
Old Dec 11, 2010 | 07:55 PM
as long as you keep the same profile of the tire, you'll cut down the revs of the motor
all around, 15's are a little better, unless you want to be completely original
Old Dec 11, 2010 | 08:01 PM
Archer's Avatar
Marty -
The only problem with 14's are that they don't seem to make/have available all the sizes/profile tires they used to. So in that case, the 15's are easier to deal with - these days, and yes, you can match the diameter to keep your speedo accurate, if you want/need to.
The only exception would be if you were doing a "correct" resto, but with the 383, that's should be an issue.
Old Dec 11, 2010 | 10:38 PM
Leem's Avatar
Thanks for the replies. Ya...14 inch doesn't allow for a lot of tire choice, but I was thinking of the TA radials which do come in 14 inch sizes. I'm sort of limited to choice of rims as well. My front has the 5x4 pattern (swapped in a pre 73 disc brake setup) and my rear has the 5x4.5 bolt pattern.
Marty
Carrico_IL
Jul 18, 2018 05:15 PM
Steffany
Apr 3, 2012 11:34 PM
juven
Jul 31, 2011 04:24 PM
filmsurgeon
Sep 5, 2008 03:08 PM
mcwulf30
Apr 25, 2007 02:38 AM
