16 DEGREES OF TIMING ?
I am in the process of dialing in the timing on a 318 I dropped in my belvedere I have it at 16 degrees.
1. Is that to much?
2. Does detination sound like little cha cha cha cha sound once you get to a certain RPM
it seems to run real well at 15, 16 and 17 degrees.
any info would be great
Thanks
1. Is that to much?
Thanks
16 deg is a bit much. detination.. sounds like glass breaking in the cylinders.(high pitched tink) manly happends when your lugging an engine. sounds like you could be a tooth off on your timing chain? bout 10 deg .. what year is your engine?
the motor is a 79 casting with 9.6 to 1 compression pistons , i did a little porting to the heads, i have a mild comp cam, and am running an edelbrock intake and carb.
I installed the timing set straight up when i put it together. i had the timing at 13 degrees and it was sluggish i bumped it to 15 and it ran great i was expirementing with the timing and it just got better with the advanced timing ( all the way to 17)but i am not sure if the motor is detonating or not i have a small sound that kinda sounds like a small exhaust leak when i punch it in third gear.
don't want to do any damage but want good performance.
That is the only time that i heard any kind of noise other than the exhaust and a little valve tapping that i seem to have.
I have read that some of the balancers on the 70's motors can be off quite a bit so maybe that is it.
Is the noise loud where you couldn't mistake it ?, because the noise i was hearing was pretty faint maybe sounded like a little bit of an exhaust leak tapping i don't want to do any damage but i want to get this thing dialed in.
if I keep it in 1st gear and drop the pedal I should here it correct?
well what im trying to say is if you lug an engine and hammer the throttle down you will hear it detionate...if it will detionate. its a good thing that you are concerned about it. if its bad enough you can lose the crank. i dont know what your funds are like but a shop can test for detionation.
Yeah my initial timing at 1000 rpm with the vacume advance disconnected and vacuume port plugged is at 15
I bumped it up to 17 and it ran even better, but i just am not sure if i am advancing it to much.
I put it back to 15 and it runs well.
I am going to step it up again tomorrow and see if i notice any noises now that i have a little better grasp on the sound it would be making if it was detonating.
I have read tons of stuff that say that the balancers can shift due to old age and give a false reading.
I want to step it up until i hear that detonation sound and then back it off a couple of degrees, but it is hard when youhave never heard that noise before and the exhaust is pretty loud.
Thanks i will keep you guys informed on what happens, any more ideas are welcomed
thanks
thanks
i am going to play with it again this afternoon. I am going to take it up maybe to 18 and see if i can hear anything , i almost want to advance it enough to hear the "glass breaking " sound so i know what to look out for.
Thanks for all the help i will let youknow what i find out
Thanks again
Thanks again
Here is what i found out. i played with the timing and brought it up all the way to 19 degrees. On heavy exceleration under load i heard a small amount of noise definitely from the engine some place, i am still not sure if it is detonation or something else. I only heard it when i was under load and it would let up after i took my foot of the gas.
i moved it back down to 17 and it seems to run really well , starts right up, has good acceleration, idles well and when i get on it i don't think that i hear anything.
I checked my plugs and they look really nice, just a hair off white nice and clean.
so i am going to run it that way for a while
thanks everyone for the help
Luke
Luke
RamCharger
42
May 29, 2012 02:26 PM
a.johansson84
May 27, 2012 03:30 AM
