1966 monaco gas tank
Old 07-04-2008, 07:17 PM
Monacoman's Avatar
there are 3 places for lines to exit mine only had 2 used could someone tell me what each is hooked up to cause my car doesn't get fuel and gas gauge does not work, not sure which goes where
Old 07-05-2008, 06:37 AM
Monacoman's Avatar
i believe its only got a mechanical fuel pump at the motor i inspected it seems ok but the tank leaks out of the unused hole so i'm thinking because its so old could be a pressure issue since it only uses about 5 psi to run the car
Originally Posted by Doc
Gas not coming out and the fuel gauge not working are probably two diff issues. I would suggest taking the sending unit out and eye-balling it. The sending unit should come apart.
Old 07-06-2008, 06:51 PM
Monacoman's Avatar
i fixed the no gas to carb problem but \gas gauge doesnt work and one of the outlets on the tank is unused, secondly car wont start i filled the carb with gas it ran till that dried but wont take gas through the needle and fill up the float:S
I am not following you.
68camperspecial
07-25-2009 07:15 AM
bigsho
07-08-2009 06:40 PM
8287rams
05-03-2009 06:45 AM
71RR08
08-25-2008 08:40 PM
Monacoman
07-05-2008 11:15 AM
Quick Reply: 1966 monaco gas tank
