1970 Challenger tail lights problem
Old Feb 10, 2014 | 05:20 PM
djmaster219's Avatar
hi i am new to all this, i have been reading a couple of threads on here and they do help. im 18 years old and my Dad is a owner of 2 1970 challengers. one is a orange hardtop 440 sixpack 4 speed and the other is a red convertible 318 auto trans. right now the hardtop is being restorated on a rotisserie getting painted and the other is just sitting. i felt the need to fire the convertible up and just play with it.
My question today is my tail lights are flashing all the time right when i connect the battery. why is this? it seems to be the hazard lights but when you look at the dash it reads im indicating to turn left only.
another problem is that my key wont turn to the off position. its stuck on battery position and wont come out
please need some advise thank you
Old Feb 10, 2014 | 06:18 PM
Could have some lights out in the dash. There is a lever on the steering column that needs to be pushed to get the key to the off/ lock position. And a button for the 4 way flashers
Old Feb 10, 2014 | 07:24 PM
First thing to do is determine what is causing this
Could be a wiring/ tail light harness problem
Could be a stuck / failed stop light switch.
Could be a bad turn signal switch, which also contains the 4x flasher switch, or switch left on as mentioned above
Don't these have a reverse lockout? IE you have to have the trans in park or stick in reverse to lock the column?
AliceSML79
Aug 22, 2014 03:28 AM
mach3107
Feb 9, 2011 10:46 AM
cudawes
Apr 27, 2010 04:20 PM
68fastbackpete
Apr 10, 2010 05:19 PM
mamapeep
May 12, 2008 05:37 AM
