1974 Dart swinger a/c delete
Old Jan 24, 2012 | 02:43 PM
Ronvonie's Avatar
I have a 74 swinger, 318ci, I am going to remove the a/c system in this car, it does not work and for what I will be using the car for I would rather ditch this 100lbs of dead weight. Question #1, now that the a/c motor will no longer be there what do I do about the alternator belts? Just run a smaller belt or do I need to get a tensioner? Question #2, what do I do about the lines that are coming from the radiator? Cap them off or is there a bypass that needs to be run? Any help would be greatly appreciated. Going to start the dismantle in 5,4,3,2...
Old Jan 24, 2012 | 03:13 PM
Easy way would be to remove the compressor and leave the bracket. Install an Idler on the bracket. Air cond evap mounted in front of the radiator can be removed. IT does not connect to the radiator.
Other wise you need NON air cond pulleys
Or Myguiver the belt alignment and belt size
Old Jan 24, 2012 | 07:36 PM
mr340's Avatar
There are different accessory brackets for non A/C motor, try to find them and do it right. Nothing worse than tossing a belt @ 3000RPM
Old Jan 24, 2012 | 07:44 PM
Silverick's Avatar
I agree. I did this with a 383 and
#1 - it looked wrong!
#2 - it was a lot of work to make it look that way!
#3 - it would throw belts :-(
I finally found the correct brackets and pulleys and it was right.
Old Jan 25, 2012 | 09:07 AM
Ronvonie's Avatar
Thats what I figured, i have been looking for the non a/c brackets and pulleys, is there anything else I am going to need to remove?
Old Jan 25, 2012 | 10:21 AM
Brackets....http://www.bouchillonperformance.com...racketkits.asp
Pulleys....http://www.bouchillonperformance.com/BPEpulleys.asp
Old Dec 7, 2014 | 04:36 PM
kevinnjanet's Avatar
So how did you deal with the vents inside the car? They deleted it on my 360 I just have the box inside the car
Profyrfyter
Dec 17, 2020 01:22 PM
1974DodgeDart
Aug 12, 2014 12:48 PM
72bird
Aug 4, 2012 09:58 PM
mopardrt
Feb 9, 2010 06:20 AM
Jesan138
May 18, 2009 08:15 PM
