2000 cirrus 2.4 blown pcm/ecm fuse
Old Oct 2, 2013 | 07:15 AM
Darren Muncy's Avatar
Hi im working on a 2000 cirrus 2.4 where do i begin, origonal problem overheating, replaced water pump timing belt and idlers. well it had also blown the head gasket pulled head had reworked and installed then the fuel pump died. Replaced fuel pump assy. ran for two weeks fine, then after a hour+ drive pulled into store to get gas then pulled up to car wash stepped on brakes and car died.
after some looking found pcm fuse blown, replaced fuse then it blew as soon as the key was turned on. so far i have replaced the computer and checked the fuel pump and coil pack both good still blowing fuses and wont start?????
Any Ideas of where to look next?
Old Oct 2, 2013 | 10:04 AM
2000 Cirrus SR20 Air Plane ??????
If So....
Sounds like the main power wire is shorted to ground.....
Old Oct 2, 2013 | 10:23 AM
Hi well when i unplug the asd relay the fuse holds, also i have unpluged the coil pack and fuel pump with no change, could it be the cam sensor or crank trigger shorted? i havent unpluged them yet, looks like the main oxygen sensor is fed from that fuse also. Chasing shorts arent my favorite. any sugestions?
Old Oct 2, 2013 | 10:27 AM
Ohh LOL 2000 chrysler cirrus i wish i had a plane.
Old Oct 2, 2013 | 10:39 AM
I dont have a wiring dia. in front of me..... But I thought the PCM was on a fuse all by itself?
Old Oct 4, 2013 | 09:00 AM
Found problems in the wire harness
Attached Thumbnails 2000 cirrus 2.4  blown pcm/ecm fuse-photo-1.jpg   2000 cirrus 2.4  blown pcm/ecm fuse-photo-2.jpg   2000 cirrus 2.4  blown pcm/ecm fuse-photo-3.jpg
Old Oct 4, 2013 | 10:45 AM
Good Deal....Looks like there was some work done their before....
Looks like it got oil soaked and just fell apart????
Old Oct 4, 2013 | 11:23 AM
Thanks for pointing in the right direction. and yes it had some oil leaks when i started working on it so the wire insolation just crumbled which caused the short. crappy wire and poor maintenance... i have some wireing to replace and hope it starts.
Thanks again.
Old Oct 4, 2013 | 12:12 PM
Good find ! Some idiot got to it before !!
Darren Muncy
Oct 5, 2013 03:33 AM
mark383
May 10, 2013 05:05 AM
evildesirez
Sep 30, 2012 10:41 PM
Beerstop
Nov 5, 2011 11:17 AM
mrstude
Feb 19, 2011 04:46 PM
