2006 dodge dakota steering problem
Old Apr 14, 2014 | 10:27 AM
ottosen@chorus.net's Avatar
After replacing almost all suspension parts I still have play in the steering wheel.
New upper and lower ball joints steering shaft etc.
Still have the sloppy play. Just 50000 miles on it. Started a 38K.
Has close to an inch both ways. Also have a rattle in the column when I go over railroad tracks.
Seems like there is some kind of adjustment or something to tighten this up???
I am sure it is in the shaft. I replaced the lower u joint shaft and it made little if any difference.
Help
Thanks
David
1968 Sport Sattelite Conv 383
Old Apr 14, 2014 | 01:32 PM
Steering gear my be no good...... Have someone turn the wheel back and forth, while you look at all the moving parts for slaup..
Old Apr 14, 2014 | 06:02 PM
moparted's Avatar
it has rack
Old Apr 14, 2014 | 06:28 PM
Originally Posted by moparted
it has rack
Oh...And those dont go out... Rite....
Old Apr 14, 2014 | 06:47 PM
Mr.4spd's Avatar
Had to replace the steering box in my Ram at 45K miles because of slop. Do yourself a favor and put a genuine Mopar box in it, or do it twice like I did.
Old Apr 15, 2014 | 09:44 AM
it has rack
I also replaced the rack. Had a leak.
Old Apr 15, 2014 | 09:48 AM
2 Wheel Drive or is it a 4 Wheel Drive????
Old Apr 15, 2014 | 09:52 AM
Thanks for the reply. Wondering if there is a way to make a adjustment or to tighten the steering column shaft itself. Tried Turning wheel back and forth and could not see any play there. The noise seems to come from the steering column. Like something needs to be tightened. I am thinking there a bolts that might be tightened where the column shaft meets the knuckle????
Old Apr 15, 2014 | 12:38 PM
ReCheck the Rag Joint...... Also Wiggle the steering shaft to see if maybe the plastic shin went bad between the inner and outer shaft?
Just a note.... Some of those problems where covered under a Recall, you might call the dealer and give them your VIN # and see if your was one that needed to come in for the recall?
Old May 3, 2014 | 01:09 PM
Thanks for the info I will call the dealership. \
Where is that plastic shim located? How to I get at it?
I know where the shaft goes down from the steering wheel. I do not see how I can get inside there if I have to.
Any help would be appreciated. It is driving me to Drink.
Thanks
David
Old May 3, 2014 | 04:31 PM
Rack ! I would check the mounting rubbers
Old May 4, 2014 | 05:57 AM
pro-tech's Avatar
it has rack
Really No ****,
So Mayfield once again you jump in with no response on what you think it is.. Or how to fix it...
Old May 4, 2014 | 06:03 AM
pro-tech's Avatar
If it is a tilt wheel there are 3 E30 (male torx) screws that come loose and need to be tightened you do have to get into the steering column and you do need special tool to perform this procedure....Bill
Old May 4, 2014 | 07:57 PM
moparted's Avatar
Originally Posted by pro-tech
Really No ****,
and it took you 3 weeks to respond.
Old May 5, 2014 | 06:38 AM
pro-tech's Avatar
But it still isn't fixed as you can see because you give no help just stupid comments. He posted on 5-3-14 and 3 weeks ago your help did nothing... Maybe you should just not post if you have no help to offer.. I do have things to do, and don't catch all the posts but do try to help offer a fix/help if I can..
Old May 21, 2014 | 08:06 AM
thanks for your help all of you. I still have the problem. I guess I have no tools to pull the steering column.
Old May 21, 2014 | 08:08 AM
thanks I will have to do that. I am scared of dealorships but ......
dgbcharger
May 4, 2015 05:56 PM
dgbcharger
Apr 12, 2015 05:43 PM
philsbrandt
Apr 1, 2015 01:51 PM
ottosen@chorus.net
Jan 27, 2014 07:26 AM
1 Bad Mirada
Jul 7, 2009 08:01 PM
