225 main bearings
Old Oct 2, 2013 | 04:29 AM
mr.225's Avatar
225 main bearings
hows it going everyone!!!first off,first time posting here and id like to say thanx for any help that can be offered, as im semi noob with working on cars...i have a 68 225 im rebuilding and wanted to replace the main bearings,mind you ive never done main bearings before...i ordered a set of 4092M standard set assumeing thats what i needed for the build...they offer .01,.02,.03,.04 sizes...when they arrived they were waaaaaaay to big...how would i find out the right size for this block???
block number 2806830-4 other punches 0202 AAWJ BH
its a 225 1bbl 3.7 if i matched the block correctly?
Old Oct 2, 2013 | 05:13 AM
DO you have the old bearings ? There will be a part# on the back.. As for them being too big ? The crank may have been rebuilt sometime previously in it's life So you may need a .010 or .020 undersized bearing What type of rebuild are you doing ? Is the crank out of the motor?
Would be advisable to have it checked
Old Oct 2, 2013 | 08:25 AM
mr.225's Avatar
crank is in the motor still...the motor is in a lull...it has a hydraulic pump attached to the front of the engine bolted to the crank pully so i didnt want to pull it out as its a pain in the @#$...i was just tgoing through it doing rings new haead gasket and so on and figured whille the pan was down getting a scrubbing id do the crank bearings and make sure everything was torqued down tight since its an old engine...the stadard crank bearings i got were like a 1/2 inch to big...that seems more then .01,.02,.03,or .04 bigger then a standard crank grind...thats why i decided id check here for some advice on how to determine the crank bearings size...
Old Oct 2, 2013 | 08:49 AM
moe7404's Avatar
why did i not hear a word about using a micrometer?
Old Oct 2, 2013 | 11:16 AM
Some type of industrial engine ???? Were their #s on the old bearings ?
Old Oct 2, 2013 | 02:23 PM
I want to help but don't understand if the crank and bearings are still in the block how do you know they're too big?
1966DartConvertible
Nov 25, 2010 09:57 PM
hippo204
Sep 2, 2010 08:17 AM
Bossta
Mar 2, 2010 08:13 PM
Slice
Feb 7, 2010 07:47 AM
pjmopar
May 15, 2009 01:48 PM
