318 carb requirements
Old Mar 30, 2009 | 08:56 PM
craveman's Avatar
Senior Member
i found a formula for figuring out the cfm requirements for an engine. the formula was
Cubic inches x maximum used rpm / 3456 = ideal cfm.
Ideal cfm x voulumetric efficiency = actual cfm
so i put my 318 into the equation. maximum hp is at around 4000 rpm so i went with 5000 rpm cause thats the highest i ever had it. Mopar muscle magazine said that racing only vehicles had a volumetric efficeincy of 100%
a high performance street/strip was about 90-95% VE
a stock to slighly modded motor runs at 80-90% VE
im going to assume with the 302 heads that i gasket matched, the headers, and a 4bbl intake manifold that im running around 87% VE
318x5000=1590000 1590000/3456=460 ideal cfm
460x.87=400 needed cfm.
in the magazine article they said you dont want to go less than the needed cfm but i figured i need between a 390 and 450 cfm carb for my application. I was wondering if anyone knew of a carb that came stock on something that i could use instead of shelling out 300 bucks for a new one. I was shocked to see that i needed a carb this small but i assumed 600 or 650 was too big.
Old Mar 30, 2009 | 10:01 PM
craveman's Avatar
Senior Member
it just seems like 600 is way too big. ive talked to other people that said that when they put 600's on they got sluggish
Old Mar 31, 2009 | 01:09 AM
johnthegoalie's Avatar
thinkin with me dipstick
carter/edelbrock has a 500
Old Mar 31, 2009 | 05:49 AM
craveman's Avatar
Senior Member
i was thinking of the edelbrock 500 with manual choke but wasnt sure if that was going to be too much for my engine
Leem
Apr 15, 2014 10:04 AM
northcoasttip
Sep 26, 2011 11:23 PM
deadkelly
Aug 30, 2009 07:24 PM
YellowTruckOfAwsomeness
Feb 24, 2009 01:19 PM
sharkie
May 2, 2008 09:48 AM
