stroking a 318
Old Mar 30, 2009 | 11:44 AM
craveman's Avatar
Senior Member
stroking a 318
I know many people say just build a 360 but i want to build a 318 stroked with a 360 crankshaft and rods. i was just wondering what else would need to be done with this because the 360 is externally balanced and im not sure how to convert this. this isnt going to be a high power application im just doing it for fun. i got an engine from a 80 lebaron with 43000 miles on it for 100 bucks from the local u pull it and it runs great. i have a set of 302 heads and a set of 360 heads. i want to build this with mostly junkyard parts except for stuff that has to be replaced. Its just a summer project for me and my friend hes building up a 2.4l turbo and i decided to do a stroker engine which will eventually go into a very low budget rat rod.
Old Mar 30, 2009 | 02:13 PM
Why not stroke a 360 as there are kits for it out there.
Old Mar 30, 2009 | 02:21 PM
craveman's Avatar
Senior Member
its a project were each doing for fun. every summer we pick something and then build it. last year i put a 750 cc motorcycle engine in a riding lawnmower with a racing quad rear axle in it. quite fun but im set on building a stroked engine and i already have a spare 318 so actually what i was thinking about is putting the one with 40000 in my fifth ave with ported and polished heads and a 360 2bbl cam and a 4bbl and then stroking my motor.
Old Mar 30, 2009 | 03:22 PM
craveman's Avatar
Senior Member
jesus it seems when you mention stroking a 318 engine everyone thinks you just shot the pope or something. i post on a few other forums besides mopar and ive gotten some pretty rotten responses to them. at least you guys are civilized and usually quite helpful when you offer responses but there are a few other sites that i will no longer visit anymore. thinking of dropping the whole stroker idea because of those A##holes
Old Mar 30, 2009 | 04:39 PM
haha
dont let others get to you
Old Mar 31, 2009 | 03:07 AM
Polaradude's Avatar
I wanna see a pic of that lawn mower, that sounds wicked. Stroke the 318, I wanna see that too.
Old Mar 31, 2009 | 05:52 AM
craveman's Avatar
Senior Member
when we get the roof of the garage off of everything ill take a pic if its still usable. too much snow is bad for weak roofs.
Old Mar 31, 2009 | 09:34 PM
theomahamoparguy's Avatar
360 CRANK WITH 318/360 MAIN JOURNAL.
Originally Posted by ryan_e
pretty sure if you want to put a 360 crank in a 318 you gotta cut down the mains cause they aren't the same size,
Mopar performance sells a 360 crank with the 318 size main journal size.
The forged version is part# p5007253: 3.58 stroke 318/340 mains.
The cast version is part# p5007257: 3.58 stroke 318/340 mains.
The cast version is reasonably priced and has the radiused type of main bearing journals that are stronger than the original type.
ORDER THEM NOW BEFORE THEY GO BANKRUPT!!!
waham87
Feb 22, 2013 06:46 PM
hcharles
Feb 5, 2011 03:52 PM
TallChris
Dec 1, 2010 03:29 PM
LittleSpark
Jan 15, 2009 09:06 PM
ProEmaster
Jun 6, 2007 11:31 AM
