318 Compression test=90-78-60-40
Old Oct 8, 2014 | 10:06 PM
65civilcuda's Avatar
Red face 318 Compression test=90-78-60-40
I am a college student with a 65 cuda with a 318, I recently ran a dry compression test with 90-78-60-40 as the results on one head. Has anyone had similar results? I bought the car with ivory colored sludge oil. The previous owner replaced the head gaskets without getting the heads surfaced. I assume the problem is a warped head. I am a broke college student who can't waste money machining/rebuilding/replacing without some prior knowledge. I plan on doing a wet compression test but I am assuming it's not a piston ring problem with the decreasing compression numbers.. What other problems could cause this? Thank you.
Old Oct 9, 2014 | 06:11 AM
From the sounds of what I just read. It appears that an Overhaul would be in order. I would suggest that if you are running short on money, that you check with the collage your attending and see if there Automotive technology department might be interested in a class project for the rebuild.
I have done this in the past with good results on some projects with thin funding.
I think if you short cut it at this point, your just going to chase your tail.
Just my 2 cents
Old Oct 9, 2014 | 12:19 PM
ivory colored sludge oil. If it has been in the engine any length of time the bearings are shot !!!! Rebuild time !!!!!
Old Oct 9, 2014 | 02:55 PM
That is usually water in the oil. Do a cooling system pressure test first.
Old Jan 20, 2015 | 12:28 AM
Thanks for the replies!
You reinforced my doubt about the engine. I don't have the time to try different things, so I bought a good engine for $400. Thanks for the help!
Old Jan 20, 2015 | 06:55 AM
Hope it runs good?....
jimiheadstone
18
Oct 9, 2013 02:33 PM
74Runneer
Jun 26, 2013 05:11 PM
raycan2
Jan 26, 2013 12:46 PM
scotty
Jan 12, 2012 05:20 PM
Altosax
Oct 7, 2011 04:59 PM
