318 cylinder limits?
Old Mar 31, 2009 | 11:15 AM
craveman's Avatar
Senior Member
ive seen people bore it 060 over but that is the logical limit for the 318. youd be better off boring 40 and then if you ever do another rebuild you can use the same block.
Old Mar 31, 2009 | 04:42 PM
agreed
Old Mar 31, 2009 | 06:20 PM
craveman's Avatar
Senior Member
watch how much you mill the deck and heads too because youll have to mill the intake as well. whats your choice for an intake and carb?
Old Mar 31, 2009 | 09:03 PM
theomahamoparguy's Avatar
Originally Posted by TwistedWrenches
Ive decided to take an old presmog 318 for my duster build. I know pretty much exactly what Im going to do to it, but I was curious if any of you know the limits to boring a 318. I know .40 is acceptable, but is going .60 safe?
I mean bigger is bigger unless its not safe. I noticed that I can get the KB 167's in .60 over and thought "WHY NOT". But figured Ide ask first.
From what I've read, some of the early 318 LA engines from 1967-1969 (and the earlier polysphere engines) can be bored to 4 inches. Careful testing of the cylinder bores with a sonic tester is definitley required and only about 40% (less?) will pass. At sometime in 1969 (supposedley) the castings were modified and the 318 cylinder walls were made thinner. The '69 and later blocks should limited to only a .040 overbore and only .030 from about 1982 and up.
Anyway, I would stay with the .030 oversize pistons. If you want to see how thick your cylinder walls are, your machinist can check them if he has the equipment to do so. Yes this will cost some money, you've got to weigh your options.
I have heard of an early polysphere engine that a guy built that went all the way to 406 cubic inches with a 4 inch crank and 4.020 bore. {torquey!!}
Enjoy!!
Old Apr 1, 2009 | 03:28 AM
I've always told people to only bore if you have to. If you have to only bore what you have to as well. The more wall you take away, the hotter it can run so you need to make sure that you have a really good cooling system for it. .030 is ok, .040 is my limit (and there has to be a good amount of wall left for that even), and .060 is just too much in my head, but that just me.
Old Apr 1, 2009 | 03:59 AM
craveman's Avatar
Senior Member
the polyshpere can be bored out more than a regular block because the walls were a lot thicker.
Old Apr 1, 2009 | 12:04 PM
Polaradude's Avatar
Don't be scared little Timmy, .060 over won't make you fall in the well.
hahaha
Old Apr 15, 2009 | 05:10 PM
deadkelly's Avatar
hahaha
hahaha
SPICOLIE203
Mar 25, 2012 09:20 AM
Imperial1973
Sep 5, 2009 10:17 AM
Chuck_S
Jun 25, 2009 09:09 AM
richk2843
Jun 21, 2008 11:29 PM
buttslapper
Oct 1, 2007 06:32 AM
