318 issues
Old Aug 4, 2009 | 09:12 PM
Monacoman's Avatar
318 issues
I posting it here as well so more people see it
Ok I am officially stumped i have a 66 dodge monaco with a 318 it bogs when i hit the gas and as of yesterday it wont run for longer than 5 mins. So heres the list of things ive done. new push rods, new head gaskets and intake gaskets, rebuilt carb twice, rebuild distributer, new coil and wires and plugs, new water pump, timing checked.
tomorrow i will readjust air and fuel screws by screwing them in and pulling them out 2.5 turns each than hooking up vacuum guage and adjusting till i get best vacuum reset timing and check if all valves are opening. but im so lost on what it could be any suggestions will be amazing im trying to get it goin good for mopar fest on the 15th.
Old Aug 10, 2009 | 08:32 PM
Monacoman's Avatar
mine were black i replaced them i dont know where to set the screws on it i think it may just be trial and error? also my fuel guage doesnt work if i ground it it reads full if not it reads empty had the sending unit rebuilt when i had the tank relined
Old Aug 11, 2009 | 11:32 AM
Polara_68's Avatar
MoparMania-no cure for it
plugs are black..?
sign of running rich..
is the choke & choke pull-off working correctly..?
is the float level set correctly?
is there a speck of dirt or rust blocking the needle & seat open?
(the above can also cause flooding, and gas in the oil as well)
Old Aug 11, 2009 | 08:16 PM
Monacoman's Avatar
ty i sent the carb back to be rebuilt AGAIN and they said they never rebuilt it got me kinda mad but hopefully it works everything else has been changed
Old Aug 13, 2009 | 09:50 PM
Monacoman's Avatar
thanks everyone after a lot of time and money shes runs like a dream ready for mopar fest body is blah but original motor
Old Aug 14, 2009 | 05:41 AM
72RDRNR's Avatar
Good to hear you got it all sorted out! Did you get the fuel gaguge fixed? If not this is something to look at (thanks to Scotts74birds):
http://www.moparfins.com/Repairs/Fue...uge_Repair.htm
dchamp
Dec 23, 2013 09:01 AM
bjm6469
Jan 27, 2013 08:31 PM
hcharles
Feb 5, 2011 03:52 PM
ColeTrickle
Jul 24, 2008 08:36 PM
66coronetgirlie
Feb 25, 2008 05:40 AM
