318 issues?
Old Jan 24, 2013 | 08:39 AM
bjm6469's Avatar
318 issues?
I have a 1974 dodge charger with a completely stock 318 in it and I have recently started to drive it alot more often than before as I have obtained my License. The other day I was going up hill trying to pass someone, so I floored the gas. As usual the car started to move quickly but started to bog, almost as if I ran out of fuel. Which I knew wasn't possible as I filled up the day before. But it would have small moments of power and stop again. Any ideas on what it is could be?
Old Jan 24, 2013 | 08:54 AM
Archer's Avatar
b -
Welcome aboard.
You have a 2 ton car and an engine producing less than 200 hp at the rear wheels, with most like 2.73 gears.
So, sluggish uphill performance is kinda expected.
The "bursts of power" usually implies carboration issues, and with a stock 2 barrel carb that's nearly 40 years old, it might be due for a rebuild or at least a cleaning.
Sure, bad gas, tranny issues, etc could factor in, but best to take one step at a time.
First, I'd run the tank nearly empty, use a fuel system cleaner and fill with "good gas" from a known reputable station.
Naturally make sure you have adequate and clean tranny fluid and motor oil.
Old Jan 24, 2013 | 08:58 AM
SixtySevenDodge's Avatar
I know this is probably a bonehead response but make sure all of the obvious stuff is working properly and/or adjusted. Fuel filter, proper carb adjustment, spark plugs, correct timing. I did have an issue with this before with another car I used to own and it was a clogged fuel filter. The motor was an late 60s LA 318 so pretty much the same motor.
Old Jan 24, 2013 | 09:23 AM
bjm6469's Avatar
I haven't changed the fuel filter in a while, or the air filter, or cleaned the carborator. Lol. Looks like I'll be busy!
Old Jan 24, 2013 | 10:52 AM
I wouldn't mess with anything until you change the fuel filter
Old Jan 24, 2013 | 11:29 AM
also check to see fuel lines aren't getting hot. i had a car experiencing vapor lock that had the same sort of symptoms yours is having.
Old Jan 24, 2013 | 02:45 PM
bjm6469's Avatar
How would you go about checking the line temperatures? Also, I was thinking about beefing up the engine a little bit. Starting with a rebuild kit, a hydraulic lifter and cam set (.475/.475) a stall torque converter, around 2000 RPM, a shift kit, a new carburetor, and high compression pistons. It sounded like it would round the engine off well. Thoughts?
Old Jan 24, 2013 | 09:11 PM
This problem could have many different causes, some of them multiple.
Has the car ever had any serious maintenance/ restoration?
If not, for starters, factory cars have two flexible fuel lines, both under "vacuum." One is immediately out of the fuel tank, the other is at the inlet of the pump.
So it could be the screen in the tank sender, either or both of those hoses collapsing, the pump may be failing, the filter may be plugged.
OR NOT
Might be other problems. Frankly, fuel line temps are NOT usually a problem on the highway at speed, where airflow has time to cool things down. Vapor lock/ fuel boiling, type problems are usually hot day/ after park (hot soak) or at very low traffic speeds on slow/ crowded streets, or in parades.
Old Jan 25, 2013 | 05:20 AM
Gorts 5th's Avatar
Smile
nice cam selection throw a set of 360 head's on it and and you will have a hot 318 change the gear in the rear. look at the lift on this cam will work better than any in it's duration with the long-rod 318's
Advertised Duration (Int/Exh): 262/268
Duration @ .050 (Int/Exh): 220/226
Gross Valve Lift (Int/Exh): .475/.494
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1400-5800
this will probably be my next choice or the duration right above this selection
the comp cam i have now has more duration but less lift
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 226/234
Gross Valve Lift (Int/Exh): .494/.513
LSA/ICL: 110/106
RPM Range: 1800-6200
i have built a few 318's over the year's my latest is the fastest .
Old Jan 25, 2013 | 09:57 PM
bjm6469's Avatar
what would you change the gear to?
Old Jan 25, 2013 | 10:20 PM
It probably has an 8 1/4 rear end so a 3.21 gear. You could have either a 904 or 727 trans behind your 318. The cam mentioned could be used with the stock converter Stock HP converters were usually around 2000 2200
I know my stock purchased new, long since gone 77 Volare had a converter with a sticker (Hi Stall).
I would also stick with the stock pistons, late 80's 306 ???? heads NO Hi Compression pistons unless You want to run race gas. keep it around 9.5x 1
Old Jan 27, 2013 | 08:31 PM
bjm6469's Avatar
Race gas as in just higher octane? like 91 or so?
dchamp
Dec 23, 2013 09:01 AM
hcharles
Feb 5, 2011 03:52 PM
Monacoman
Aug 14, 2009 05:41 AM
ColeTrickle
Jul 24, 2008 08:36 PM
66coronetgirlie
Feb 25, 2008 05:40 AM
