318 long block ID
Old Nov 20, 2010 | 01:24 PM
tracktor312's Avatar
318 long block ID
hi guys foung a 318 long block with the number 4006750-318-1 can't find it listed anywhere! when they say oil pans don't fit van and truck engines do they mean just in the van or truck ?? or is there a diff. somewhere else?
Old Nov 20, 2010 | 02:58 PM
I don't see what you're getting at. I'm not familiar with the newer magnum/ EFI engines, I understand they made a change in the block design, and that newer 318's now take basically a slightly modified 360 pan
On the OLDER engines of the first LA and up through the '80's, 318 pans won't fit a 360 because of the large rear journal
The difference as to vans and pu's is NOT the engine, but the pan itself, cars mostly using front/ center sump pans, and pu's using rear sump pans.
I cannot speak for differences in heavy truck/ motorhome engines
Old Nov 20, 2010 | 04:53 PM
I believe the engine is a 1974 on the side is cast 5-18-74 but here is an example of my question!
(Please be sure that your engine is not a 360 and that it did not come out of a truck or van, it will not work for those applications!)
the engines are the same it the fit in the vehicle thats diff. correct.
Old Nov 20, 2010 | 04:59 PM
theomahamoparguy's Avatar
what does this engine look like. The date of the casting is on the side of the block.
for the most part. vans used the same pan as the pickups. (not the 71 and earlier pickups though, they were different). Cars used the center sump pan.
Old Nov 20, 2010 | 05:06 PM
yes the engines a re the same. Just the pan and oi; pickup are different. Also, 360 engines are externally balanced and the torque convertor in the trans must be compatible with the 360. (with a balance weight on it.) the 360 block also has slightly narrower ears for the mounting of the engine mounts. (can be easily accomadated for though with some washers used as spacers if you got the 318 mounts and want to install a 360 in place of a 318).
BoltonDodge
Oct 24, 2014 07:58 PM
gold_dredger
Feb 8, 2014 07:28 PM
medic11
Aug 6, 2013 03:50 AM
scotts74birds
Oct 7, 2010 09:07 AM
LittleSpark
Jan 15, 2009 09:06 PM
