340 street build with timing questions
Old Jun 14, 2018 | 03:55 PM
Bob Gregory's Avatar
What is reccorecomm base timing with a 472 lift, 260 duration and 11:1 comp, thunder series 650 Edelbrock carb and a vacuum advance Mopar distributor?
im getting back break up under heavy load, throttle, at 2500 to 3600 then it Roars.
Old Jun 15, 2018 | 07:02 PM
With todays fuels I would start with about 15deg btdc vacuum advance disconnected See how it runs. You may need to modify the distributor
Old Jun 16, 2018 | 03:55 AM
Problem solved.
Pinned the vacuum advance and set base at 12 btdc.
trans has manual vavle body and was starting in second gear.
Car hauls ***, gets sideways in second, good idle and street characteristics.
Total advance about 34-36, no hesitation and good plug reading, no detonation.
Thanks for your replies!
Bob Gregory
Jun 14, 2018 04:16 PM
70newport
May 29, 2017 07:30 AM
75Duster360
Nov 21, 2013 02:35 PM
SPICOLIE203
Dec 29, 2011 09:42 PM
Barfly
Apr 17, 2011 09:15 AM
