360 LA Dakota. Budget!
Old Feb 18, 2009 | 05:59 PM
First off, welcome to the forum.
Second, LA motors are not the same as Magnum motors. The trannies will bolt up but thats the only thing that is the same. The heads have got different port sizes, different locations, different bolt patterns, and thats just the the intakes and exhaust manifolds. The oil and water passages are different too. That is why you can not swap parts between a LA motor and a Magnum motor.
Now onto your project. You 89 dakota came with a 3.9L non-Magnum V6 that was carb. That 42RH is junk, even for a 3.9. Trust me, I tore through 3 of them in 2 years, and 1 of those 3 was a factory reman from Chrysler.
Your best bet is to find a smashed up dakota R/T and swap in the motor, tranny, wiring, and computer. That will give you about a 14-15 sec truck in that 89 Dakota. Heck, even a normal 5.2L Magnum motor will get you into the low 15s with the right tires and suspension.
What are you planning on doing with this truck? What do you plan on swapping in for a rear axle as that 8.25 rear that is in both of those truck will not hold up.
Old Feb 18, 2009 | 06:37 PM
craveman's Avatar
Senior Member
I agree on that tranny being junk. as is the 3.9l.
Old Feb 19, 2009 | 08:12 AM
Old Feb 20, 2009 | 01:44 AM
You are right about the water passages. It was just the oiling system that was different.
A friend of mine had an 88 dakota, I had a 92, 00 and now an 01 and all four of those had 8.25 in the rear. I never heard of chrylser installing the 8 3/4 in the rear of these trucks.
Old Feb 20, 2009 | 01:44 PM
1) I'm not sure about that.
2) you would be better off making an adaptor plate than welding and drilling new mounting holes.
3)I would look around for an EFI manifold. The dome shape will not be working with that cam too well.
I remember a guy coming in with a 98 GC Limited with a bored and stroked 5.9 and he was running an aftermarket EFI intake. I never got to talk to him to see where he got it but someone, somewhere makes/made it.
4)I'm no help here
5)I like MSD for ignition. the stoke dizzy should be fine though, just get a good coil and set of wires.
ibstewrat
Sep 30, 2011 10:40 PM
Nov 30, 2010 12:18 PM
Oct 6, 2010 09:42 AM
timmymacnj
May 9, 2010 06:34 AM
8287rams
Apr 21, 2009 07:46 PM
