4.10 gears question
Old 02-20-2009 | 04:37 PM
78cordoba's Avatar
Member
4.10 gears question
ok so i am wondering if i find a jeep with a chrysler 8.25 with like 4.10 gears if i could pull the gears and put them in my cordobas 8.25? or wont they fit or what?
thanks a lot
mike
Old 02-20-2009 | 06:42 PM
Good luck finding a jeep (late model cherokees and some libertys) with gears that low unless someone swapped them in. I think they went as low as 3.55, maybe 3.92 if it had a tow package. Gearing that low on the street would need 33" tall tires in those vehicles.
Old 02-20-2009 | 08:20 PM
78cordoba's Avatar
Member
so if i find them tho they will be able to swap into my cordoba?
Old 02-21-2009 | 01:01 AM
crmzendrgone's Avatar
If i am not mistaken they should fit right in. I pulled my cover on my 77 cordoba and it was just like looking at the diffs that i see daily in the dodges and the liberties I am curious why you want that low of gears i was always under the impresion that those are good for off roading.
Old 02-21-2009 | 03:32 AM
They are also great if you want to run a hgher RPM down the strip.
Old 02-21-2009 | 03:34 AM
Even the Dakotas with the V6 and only got 3.92 gears at the lowest. They should swap right in though as the housings will be the same, its just the axles tubes that will differ. You might have to swap spider gears in the carrier if the axle shaft spline counts are different.
johnhuckin
03-28-2009 07:27 AM
v6spitfire
02-18-2009 11:54 PM
darkcrow
10-04-2008 02:59 PM
debby440
06-19-2008 12:55 AM
transman037
01-20-2008 10:56 AM
Quick Reply: 4.10 gears question
