4.10 gears question
Old Feb 20, 2009 | 03:37 PM
78cordoba's Avatar
Member
4.10 gears question
ok so i am wondering if i find a jeep with a chrysler 8.25 with like 4.10 gears if i could pull the gears and put them in my cordobas 8.25? or wont they fit or what?
thanks a lot
mike
Old Feb 20, 2009 | 05:42 PM
Good luck finding a jeep (late model cherokees and some libertys) with gears that low unless someone swapped them in. I think they went as low as 3.55, maybe 3.92 if it had a tow package. Gearing that low on the street would need 33" tall tires in those vehicles.
Old Feb 20, 2009 | 07:20 PM
78cordoba's Avatar
Member
so if i find them tho they will be able to swap into my cordoba?
Old Feb 21, 2009 | 12:01 AM
crmzendrgone's Avatar
If i am not mistaken they should fit right in. I pulled my cover on my 77 cordoba and it was just like looking at the diffs that i see daily in the dodges and the liberties I am curious why you want that low of gears i was always under the impresion that those are good for off roading.
Old Feb 21, 2009 | 02:32 AM
They are also great if you want to run a hgher RPM down the strip.
Old Feb 21, 2009 | 02:34 AM
Even the Dakotas with the V6 and only got 3.92 gears at the lowest. They should swap right in though as the housings will be the same, its just the axles tubes that will differ. You might have to swap spider gears in the carrier if the axle shaft spline counts are different.
johnhuckin
Mar 28, 2009 06:27 AM
v6spitfire
Feb 18, 2009 10:54 PM
darkcrow
Oct 4, 2008 01:59 PM
debby440
Jun 18, 2008 11:55 PM
transman037
Jan 20, 2008 09:56 AM
