413vs440, motorhomes?
Old Jun 4, 2009 | 08:15 PM
scotts74birds's Avatar
K boys, going to the local yard on FRi. Taking the cirrus that the wife wrecked. "2000 cirrus, great shape, great motor, just no body left behind the rear window. Would make a great "Camino" though! FRames still there!" Runs fine! Anyhow, they have a selection of 440's and a few 413's. They seen to get alot of old motorhomes. What should I look for, advantage of the 413 for a build? they all run and these guys are very cool to me. Any advice or expected prices for haggling would be appreciated. Thanks again
Old Jun 5, 2009 | 03:01 AM
Polaradude's Avatar
It's probably easier and cheaper to get parts for the 440. Just a thought bro.
Old Jun 5, 2009 | 09:35 AM
Whichever you go with, get the tranny too. From what i understand, they are a little better built than a stock 727.
What is the difference between the two? Just the bore or the stroke as well?
Old Jun 5, 2009 | 01:19 PM
What are the desirable years for castings?
Old Jun 5, 2009 | 02:04 PM
Polaradude's Avatar
The 413 is 4.18 x 3.75
The 440 is 4.32 X 3.75
Old Jun 5, 2009 | 03:24 PM
that arguement will go on forever
"thin wall's" anybody?
Old Jun 5, 2009 | 04:36 PM
Polaradude's Avatar
Casting # 1852029 from 1959-62 was a truck/ high performance 413
2658836 was an industrial 413
and 2536430 was the run o the mill 440 casting from 66-72
and 3698830 was the 440 from 73-78
and 4006630 was the 440 in 78
Hope that helps Scotty
Old Jun 6, 2009 | 07:34 PM
theomahamoparguy's Avatar
If you could go .070 over on the 413 (very possible on the motorhome or industrial block) you would have a 426. Then if you added the 4.15 crank, you would have a 471 cubic inch motor. Still, I don't think the 413 is worth as much as the 440. Try to get it for cheap$$$.
Old Jun 6, 2009 | 11:45 PM
Thanks for all the help guys. All I want is the most rigid casting as the base for a good motor. Ive seen folks spoouting the benefits of an rv block here. So far, I'm a believer in the 400 block for stroker applications.. Read the 400, though its shorter, is more rigid. Then I hear the 413 is a stronger block. I'm blessed that I have a local yard thats full of both. We have a 2000 cirrus that I have to junk, "thanks wife", and I'm thinking of doing a Jack and the Beanstalk thing. Go there with an old car hoping to get 300 bucks , and come back with a bigger motor for the RR
Old Jun 7, 2009 | 05:49 AM
If you want rigid then go with the 413 as the cylinder walls will be a little thicker. Either way, both motors I believe have beeter cooling as well.
I think there was a thread some time ago about someone putting an RV motor in a car (can't remember the body now) and they had issues with installing the headers. Could be mistaken though.
