440 cam?
Old Nov 24, 2009 | 01:46 PM
getsum's Avatar
440 cam?
im rebuilding my 440 and im not sure what cam to use. i dont want anything to crazy just a little rough idle and a little more power. the block is being bored over .030'' and i ordered kb zero deck signature series pistons the rest stock.
Any ideas on what i should get? thanks
Old Nov 24, 2009 | 03:15 PM
how much track time will the car see?
what trans?
what rear end ratio?
Old Nov 24, 2009 | 04:05 PM
getsum's Avatar
not much track time if any, the trans is a 727 with a shift kit and stock converter and im not sure on the rearend whatever the 66 new yorker had stock.
Old Nov 25, 2009 | 02:18 AM
theomahamoparguy's Avatar
I would try the comp cams HE 262. Perfect for a moild build.
Old Mar 5, 2010 | 05:31 PM
getsum's Avatar
its been a while but i just got more money for my engine and i cant find that cam anywhere. whats the part#? or another cam that would give me a little bit of a rough idle but nothing too crazy or i might hurt myself....
ohh and i plan on buying the stealth heads so i need a cam that will work well with them.
thanks
Old Mar 5, 2010 | 05:50 PM
scotts74birds's Avatar
Kind of an old thread. Go to compcams.com and download their camquest program. It will allow you to plug in your combo and recommend a cam based on that. and also gives you a performance curve based on that cam and your application. Good luck, Scotty
Old Mar 5, 2010 | 06:01 PM
getsum's Avatar
i know its an old tread but i didnt want to start a new one when i knew i already had one.
thanks i will check it out.
robert_farmelo
Nov 24, 2009 03:16 PM
piratemike
Mar 20, 2009 02:36 AM
69Fury3
Mar 17, 2009 03:06 PM
78trailduster
Mar 6, 2009 03:10 PM
67 GTX
Jan 7, 2009 05:32 PM
