440 Cam Questions.
Old Mar 13, 2009 | 02:02 PM
Commando's Avatar
Check out the performer series cams from Edelbrock.
Old Mar 13, 2009 | 02:43 PM
sounds like your looking for the cam that me and commando chose
Old Mar 13, 2009 | 06:16 PM
according to the rear your using, and your rpm range, this cam should be good for you
i used it: edelbrock cam part # EDL-2192
Old Mar 13, 2009 | 06:26 PM
deadkelly's Avatar
mate there's nothing wrong with the purple series of mopar camshafts they may be old but they are tried and tested . i have one in my 383 & for street power it's great & quite a lopey idle the sound is spot on . my engine is probably what your trying achieve , if anything i think it's the stock inlet ports that are the limiting factor . even the resto 440 six pack cam would be ok just as a street cam , but i would go p4452993 280 * dur 60* over lap 110* centerline .474 lift & recommended spring p3690933 drag mild comp . i have a full list of mopar purple cams with recommended springs ect it Say's that cam is good for 14 - 13.5 et's . if you want so more spec's just let me know or pm me .
Old Mar 13, 2009 | 06:29 PM
deadkelly's Avatar
what's the spec's for the cam you guy's chose ?
Old Mar 13, 2009 | 06:38 PM
Duration @ .05 Int/Exh are 204/214
Lift Int/Exh are 420/442
Old Mar 13, 2009 | 08:01 PM
Commando's Avatar
The specs you gave makes me believe you are looking to do something similiar to my project, the performer rpm is from what I hear a little much for the street.
From the calculations I ran with my setup, Edelbrock performer series entire kit, steel crank, and sealed power pistons, I am looking at about 400hp and 500+ ft/lbs torque. Maybe more as I don't think the program I used fully captured the cam's capabilities.
Old Mar 16, 2009 | 09:44 PM
deadkelly's Avatar
thats a towing cam even the stock 440 six pack cam's got more .
Old Mar 16, 2009 | 09:57 PM
deadkelly's Avatar
400 hp with stock heads? mmm with little cam thats pushing it i think .
Old Mar 17, 2009 | 02:17 AM
Polaradude's Avatar
PURPLE BUMPSTICK GOOD.
Old Mar 17, 2009 | 04:39 AM
Commando's Avatar
Deadkelley, the only stock parts I have are the block and the timing cover, I got the ENTIRE performer series kit.
Old Mar 17, 2009 | 03:12 PM
the cam doesnt seem to bad
Old Mar 17, 2009 | 11:05 PM
deadkelly's Avatar
hey guys fairs fair .
support mopar i reckon ,
p4452783 440 six pack 268*/ 284*, 46*overlap , 115* lobe sep , .450/458
p4286677 15.sec 272/272 *, 48* overlap , 112* lobe sep , 455/455
they will be spot on . these are still just mild but would perform well .
i thought edelbrock performer stuff was for stock replacement .
if i were spending good money I'd want some gain from my money .
if it cost the same or similar . if its not a daily driver why not have a little bit more under ya foot .
Old Mar 18, 2009 | 05:44 AM
Commando's Avatar
The heads are RPM series they market them as Performer, Performer is mild improvements, as the other RPM items are major changes to stock.
Old Mar 18, 2009 | 10:12 PM
deadkelly's Avatar
RPM'S are good .
Old Mar 19, 2009 | 02:29 PM
haha
Old Mar 19, 2009 | 09:12 PM
deadkelly's Avatar
not as good as indy hahahaha
Old Mar 20, 2009 | 02:36 AM
Polaradude's Avatar
Indy heads are the bomb.
FabioV8
94
Sep 23, 2014 12:57 PM
aatkinsonalexdatkinson
Jan 6, 2012 05:25 PM
MoparMan76
Jan 14, 2011 01:31 PM
78trailduster
Mar 6, 2009 03:10 PM
67 GTX
Jan 7, 2009 05:32 PM
