440 heads...suggestions?
Old Dec 9, 2010 | 08:44 PM
Burda's Avatar
I have a 440 in which i plan on putting in my 1966 Power Wagon. but, my main problem now is I dont know what to do for heads
does the chamber size change anything?
Is Edelbrock any good?
why are the intake and exhaust valves different sizes? and what are the stock sizes for a 440?
What's the biggest set of heads i can get without having to change the rockers?
is it better to buy bare heads and build them up or just buy a complete set?
Old Dec 10, 2010 | 09:15 AM
John Van's Avatar
Welcome,you should have posted this in the general tech section. Will need more info: how do you plan on using the power wagon? off-road,daily driver,racing? What cam? how deep are the pistons in the hole? Tire size and gear ratio? Auto,convertor size/manual trans? Tell us about any work done on the short block.
good luck,have fun!
john
Old Dec 11, 2010 | 07:16 AM
2x on what John Van said; we need to know more
what year is the 440? they got different heads throughout their existence.
edelbrock heads are good.
chamber size determine your compression, flame front, rpm range, etc.
Old Dec 14, 2010 | 01:22 PM
badsport's Avatar
45 years of Mopars
Is this not the general tech section.
Old Dec 19, 2010 | 03:57 PM
John Van's Avatar
It is now, a moderator moved it here.
Old Dec 27, 2010 | 09:41 AM
Burda's Avatar
the 440 is a '77 and out of a cop car. i plan on using the Wagon for truck pulling and a weekend driver. I'm not sure of the gear ratio. the transmission is a manuel 4 speed run to Dana 60 rear ends (front and back) with 35" tires all the way around. as for the cam, the guy i bought it from said he put a slightly "hotter" cam in it. unfortunately, I dont know much about it. hope this can be a little conclusive
Old Dec 29, 2010 | 06:45 PM
John Van's Avatar
Burda,how deep are your pockets??? The '77 440 is way down on compression,something like 8.2 to 1.To get big power out of it,you will need new pistons to raise the compression up. Did it come with heads? If it did,see if the casting number is 4006452.That was the stock head used in '77.If the engine runs,I would just use it as is.
The stock 440 has a lot of low end torque which is what you want in a truck.It can be built for a lot of power,but that will cost $$$$$,after all it is a mopar!
just my .02 worth! john
Old Dec 30, 2010 | 10:12 AM
1966sportfury's Avatar
A.K.A Bob Dodge
915 closed chamber heads will help a bit with compression.
eddy heads are good, 440 source heads or good, indy heads are good n pricey. i hear that procomp heads are good too. that's just from ppl i know that use them but they have fords.
valves are different size for a reason. the intake is bigger because gas and air comes in. gets burned, then whats left gets pushed out the exhaust which isn't much.
there is no reason to change rockers for any stock head and most after market will take stock rockers they are all the same.
build or buy a complete head. building can be cheaper but time consuming. complete bolt on heads are ready to go.
65CoronetTX
Jul 21, 2014 07:52 AM
98 SNAKE EATER
20
May 29, 2013 06:40 AM
envyedrico
Jul 14, 2010 07:35 AM
ChargerMan
Nov 2, 2009 06:42 AM
71 Duster 440
Jun 13, 2009 02:28 PM
