*****440 misfires above 3800 R.P.M *****
Old Mar 18, 2008 | 04:13 PM
Probably either lack of fuel or ignition.
Since all these cars are getting old, ANYTHING from the tank forward is suspect. Could be rust/ junk in the screen at the tank pickup, collapsing hoses on the suction side of the pump, or junk / rust/ corrosion/ damage to the fuel line anywhere.
Check the pump pressure, and check the pump for flow. Pressure/ vacuum gauges at any automotive store are just not that expensive. You should have somewhere around 5 psi, 3 1/2 absolute min. It would be good if you can safely rig a fuel pressure gauge that you can see through the windshield for testing.
Also check the inlet side of the pump. It should be able to develop a vacuum of at least 10", with the outlet disconnected from the carb.
You should check volume. Absolute min. is 1 qt in 1 min at 500rpm (slow idle)
I asssume you have electronic ignition and not points? Could be bad plugs wires cap, rotor, coil or ECU, just about anything in there that deteriorates the spark.
I'd start by changing the plugs, and use and ohmeter to check the wires.
CRITICALLY look over the cap and rotor for flash over, carbon tracking, cracks, moisture.
If you don't find something there, try another coil.
Also don't forget the common problem now that these cars are getting old---poor connections through the firewall connector. On that note, it is even possible that an ignition switch going a little south might be making poor contact. It would be worth checking some voltages
brianp
18
Aug 4, 2013 06:09 AM
65AzBel
Feb 2, 2009 11:53 AM
