440 new yorker more power
Old Aug 26, 2009 | 05:29 PM
OutlawCuda's Avatar
Senior Member
When I got my first 440 car I started at the back end,changed the gear ratio to a 3:55 or 4:10. Then to the trans. I pulled the pan and checked the way the bands and pan looked. Did a presure check on the trans . All was good so I put a B&M shift kit in it and later I built up the trans to HEMI /440 six pack specs. . Then the cooling got a once over . Did a cylinder leakage test that was pretty good . At the time a Purple Shaft with new valve springs and lifters a torker manifold and 750 Holley DFDP. I also changed the ignition to the mopar proformance electronic ignition. Headers . Dont forget the Mopar Valve covers.
tscw
19
Feb 26, 2016 06:47 PM
marcelbarth
Mar 8, 2011 08:25 PM
cyah
Jan 28, 2011 07:13 AM
DBlackford
Dec 17, 2010 05:11 PM
mopar nate
Apr 29, 2009 06:54 PM
