440 oil passage upgrade
Old Aug 6, 2018 | 11:21 PM
Dodge truck's Avatar
hey guys& gals I’m new to this forum I’m starting a engine build on a 440 I’ve been gathering parts for some time and I’m almost ready for machine work.my plans are to build a 512 stroker for my 50 dodge pick up to this point I have built a mild steel tube chassis for the truck I’ve installed Fatman stainless a-arm front end with mustang2 rack& pinion out back I have ladder bar coil over ford9 in.411 posi.the plan is to get this 512 in my frame.i would like to have some input on up grading the oil system. I have a milidon rear sump pan I have single line running from the oil pump to the pan. Any input on the Block itself would be great.ill have some pics soon thanks for your time.
Old Aug 7, 2018 | 10:19 AM
Welcome to the forum......
What are you using for an oil pump/pump cover?
Old Aug 7, 2018 | 02:34 PM
The oil pump I’m using is a melling high volume and the cover is a milidon single line going to the pan.also I would like to have some input on 440 sources roller rockers.i have bought some of my parts from 440 source. I’ve heard some hating on this company but the parts I’ve bought look good.my main concern is with the roatating Assy.good or bad the cylinder heads I’ve bought are promaxx shocker series they flow in the mid 330/350 I think these will work with the comp hyd.roller cam.571 lift /258 dur.thanks in advance any help is good help.
Old Aug 7, 2018 | 04:53 PM
I've had a hard time going cheap on rocker assembly's, I like the Comp rocker assm for street duty https://www.summitracing.com/parts/c...iew/make/dodge
Wreckless
15
Mar 17, 2018 06:20 AM
Seanzie1405
Aug 27, 2013 12:09 PM
1968newport
Aug 5, 2013 07:53 PM
getsum
Feb 7, 2011 02:54 PM
fastdakota84
Jun 17, 2009 01:54 PM
