high volume oil pump
Old Feb 1, 2011 | 06:42 PM
getsum's Avatar
i have a 440 im rebuilding and i just ordered a high volume oil pump and my question is do i need a bigger oil pick up or will the stock one be ok to run and do i need a stronger pump drive shaft?
any input would be greatly appreciated.
Old Feb 1, 2011 | 09:55 PM
1966sportfury's Avatar
A.K.A Bob Dodge
pump drive shaft should be OK i havent had a problem, the tube depends from manufacturers
Old Feb 1, 2011 | 10:39 PM
MercuryDon's Avatar
With a high volume pump you must keep a close eye on your oil level. If it gets low your pan can get sucked dry when your motor is pushed hard with all the oil ending up on the top end of the motor and none in the pan.
Old Feb 2, 2011 | 06:48 AM
John Van's Avatar
Getsum, Is this a stock rebuild,or are you putting in any go fast goodies?
Old Feb 2, 2011 | 09:49 AM
getsum's Avatar
well the engine is a 73 so it had low comp. so i got srp flat deck pistions, im ganna get the stealth heads from 440source, i have a mild comp cam for it, im ganna upgrade the intake manifold and carb also.
if i get a deeper pan than i shouldnt have to worry about sucking the pan dry then right?
Old Feb 2, 2011 | 10:01 AM
MercuryDon's Avatar
A deeper pan will definitly help. Some people get a deaper pan and then run it a quart low to gain a few HP by keeping oil spray off the crank. You add a windage tray if you don't already have one.
Old Feb 2, 2011 | 11:22 AM
MrOldart2U's Avatar
But wouldnt that negate the reason for a deeper pan to start with?
Old Feb 2, 2011 | 01:28 PM
getsum's Avatar
yeah im ganna get a deeper pan with a windage tray than il just have to be careful of driveways and bumps in the road. im ganna call melling and ask about the pickup tube. thanks
Old Feb 2, 2011 | 04:15 PM
John Van's Avatar
Since the motor is apart,I would get a hardened oil pump drive shaft to be on the safe side and replace the bushing while it's out,that's something that usually gets overlooked. With a deep oil pan you will need a longer pickup tube also. Good luck and have fun.
Old Feb 2, 2011 | 05:24 PM
getsum's Avatar
yeah i already had the new bushing put in when i had the block bored and hot tanked. i guess i gatta shell out more for a hardend pump shaft,a deeper pan, and longer pickup tube. who knew it was so expensive to rebuild a mopar...haha
Old Feb 2, 2011 | 05:32 PM
MercuryDon's Avatar
If you replace a standard 5-6qt pan with a 8 or 10qt and run it a qt low you still end up with more oil. My engine builder recommends a high pressure pump over the high volume.
Old Feb 4, 2011 | 03:20 AM
A.K.A Bob Dodge
agree you can only run so much volume through the bearings. or get a high volume and make it high pressure, its pretty easy to do.
Old Feb 5, 2011 | 06:18 AM
bboogieart's Avatar
high volume moves more oil at the same pressure. A good thing. High pressure blows things like seals and in worse case bearings, out unless everything is new, as is this case here, everything should be fine. High pressure is for high out put motors, not slightly modified. I would go with the high volume pump and your stock pan should be just fine. These motors were engineered very well for the day and work fine as built. That being said, it's ultimately up to the individual.
Old Feb 5, 2011 | 05:34 PM
scotts74birds's Avatar
"Danger Will Robinson!" Sorry, had to do that! Never really could get my head around the high volume/pressure debate. As long as there was oil in the pan, I thought things were ok. I see the point about high pressure re; blowing seals. But I thought that the role of oil is also to carry away heat. If it passes too quickly, would it not be able to absorb heat from the areas also? Sorry to go off-topic.
Old Feb 5, 2011 | 05:58 PM
MercuryDon's Avatar
High volume pumps uses the high pressure spring as well as having a larger pump casting.
Old Feb 7, 2011 | 02:54 PM
bboogieart's Avatar
Scotts 74 birds
Where did you see Will? I've been looking for him.
I agree with you, no need for either unless, High volume, you have a tired motor and need to keep oil everywhere, High pressure, for extreme high out put race motors. Stock will work very good in anything else for a long time. I've seen em run for over 40 years. Top that with after market.
JS23
Dec 18, 2014 07:12 AM
hewhobarksatdogs
Sep 22, 2012 05:53 PM
ShowYourAuto.com
Mar 18, 2011 11:24 AM
dzltd02
Oct 28, 2008 08:25 AM
robertoil
Jan 25, 2008 05:34 PM
