overcharging? how high is too high?
Old Dec 17, 2014 | 10:30 AM
JS23's Avatar
My chrome Powermaster 90 amp alt is running 15.10 volts
I replaced the voltage reg yesterday with the most expensive one I could find (short of the date coded resto pieces)
Battery voltage 12.6
voltage coming out of bulkhead (blue wire) ignition on (not running) 11.7
I put a VM on the run feed side of the ballast 10.7
Everytime I turn on the ignition I hear my Crane PS91 ign coil click.
I unglugged the ign coil then the voltage at the ballast reads 11.7
It's as if the coil is dragging voltage down. It this normal?
I did a voltage drop test (from the battery lead on the str solenoid) to the ballast. getting roughly one volt drop and 1.75 when coil plugged in.
Should I ditch the Crane coil for a standard can?
Old Dec 17, 2014 | 12:43 PM
I assume you rewired the alternator ???? re check your work..
Old Dec 17, 2014 | 02:06 PM
Sounds like a wire problem, corroded, weak connection or burnt bulkhead connecters.
You could do a continuity test to case (ground) to be sure but sounds like other stuff.
Old Dec 17, 2014 | 02:42 PM
Here some reading for you....
http://www.madelectrical.com/electri...hreewire.shtml
Just to fuel the fire....
Old Dec 18, 2014 | 07:12 AM
DDodger's Avatar
The problem is not the coil or ignition. It is bad connections between the batt and ballast
Last resort but it would fix, is to trigger a relay under the hood and use the relay to feed the ignition and regulator
Make sure the ground from regulator to batt is ok
josehf34
Aug 18, 2014 02:21 PM
josh66441
Sep 20, 2010 10:31 PM
Gordy49
Dec 31, 2008 05:09 PM
rpdavis
Dec 16, 2008 07:17 PM
dodgeaspenrookie
May 12, 2008 09:01 AM
